Since you didn't include the model number I can't answer the specific question but IFB has service manuals on their webpage. Look for it here: https://www.ifbappliances.com/support/product-help/product/laundry-solutions/top-load
SOURCE: Maytag Neptune top loader washer not filling
You have tried both a Hot fill and a Cold fill and still no water flow?
You could try going into Service Mode and turn on the water inlet valves with console commands. See page 16 of the Service Manual and see if you can turn the water inlet valves one at a time and get water to flow into the machine. Getting into Service Mode is easy to do
The Service Manual for reference. Sears Parts Direct for reference.
If still no water flow it would be time to check 120VAC on the water valve solenoids when you command them on in Service Mode. If no 120VAC present then we might have a Stuck open High level pressure switch which would disconnect 120VAC to the Control Board relays that operate to switch 120VAC to the Hot/Cold solenoid valves.
How do you feel about troubleshooting? Do you have a DVM? I have the schematic in PDF format if you need. Let me know if you want to DIY the fix......Rich
SOURCE: My Midea aw60-982 top loader
It's something to do with the draining, check your drainage hose isnt clogged, mine had a bunch of 5 cent coins stuck just near the pump.
You may have put too much clothing inside the machine. Try reducing the load.
SOURCE: My ifb washing machine top load is got error in timing display as number 4
If the error comes up as E:04, then that is an error code that the washing machine is overloaded.
Try this:
Remove the clothes from the washing machine.
Unplug the machine from the power receptacle for 1 hour.
After 1 hour, plug machine back in and run the machine without the clothes in it until it completes the cycle.
On the next load, do not load the machine with as many clothes.
Please reply to me if this works.
Thank you!
SOURCE: sir E4 code open help me ifb aw60-8061
There is no matter with this error code. Just switch OFF the device and switch it ON only after 48 hours. It will reset itself. If the error code is E2, there is no need to make it right. It has gone. Buy an other one.
