Hello, Ross -
Apparently, in Australia, Troy-Bilt products are sold through MTD.
I found the following information on the MTD Owner's Centre FAQs web page:
http://www.mtd.com.au/Page/Owners-Centre/FAQs/General/How-do-I-locate-my-nearest-servicing-dealer-for-MTD-Bolens-Troy-Bilt-Yard-Machines-or-Yard-Man-products
Servicing or locating parts for your MTD, Bolens, Troy-Bilt, Yard Machines and Yard-Man products can be done by contacting one of our Rover servicing dealers. To locate your nearest servicing dealer for any of these brands, please click here.
This is the link to the page to find the repair centre nearest Geelong:
https://www.rover.com.au/locator/
Don't be confused with the Rover logo.
Best wishes.
SOURCE: Troy bilt pressure washer 2200 psi
inlet valve connected to water inlet is stopped-up. Unscrew it, take a safety pin run through valve then take the pin and push through valve connected to pump. should do the trick. (the valve the suction hose for the soap is connect to)
SOURCE: Troy Bilt Trimmer 75SS stalls at full throttle. new gas
Hello. Let me assist you. Since your trimmer runs but stalls at ful throttle it is telling you that there is a fuel problem. Not enough gas is getting through the carbeurator to satisfy the engines needs on full throttle. Most likely the carbeurator is gummed up. A common problem. Let's see if we can un gum it by getting a can or carbeurtor cleaner. Go to any auto parts store and talk to the clerk about your need.
SOURCE: where do i find serial numbers on troy bilt horse tillers
On the old Gardenways Horse the serial number is stamped into the top of a little flange on the side of the transmission just to the right (viewed from behind) of where the handles attach. It may be covered in gunk so a douse of mineral spirits and a little scraping will reveal it.
You can download the manual and parts list from the Troybuilt site. Enter "HORSE" for the model and the serial number.
SOURCE: looking for manual for troy-Bilt super tomahawk wood chipper
here is the link to the manuals for the 47266 http://www.brentchalmers.com/
enjoy :)
SOURCE: oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
