SOURCE: need model number for Briggs & Stratton engine in
try this
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=0&LeftNav=true&model_num=147-812&serial_num=00000000
SOURCE: need a spark plug size for a yardpro self
If your mower does not have "OHV", overhead valves. You can use a Champion j19lm spark plug.
If you discover you do have overhead valves; A Champion RC12YC, will work.
SOURCE: New Craftsman 20hp Briggs & Stratton 42
first make sure the air intake screen on top of engine is not clogged with debris if thats not a concern you could have a faulty ignition coil etc your engine should have a two year warranty and can be serviced at no charge to you at your local briggs service dealer make sure and check your manual for the fine print though. Briggs makes a great engine and very rarely have I ever seen a problem allthough if you were to have an engine issue it will accur during the first few hours of opperation good luck
SOURCE: were can I GET a maintence manuel for briggs and
You can go to the Briggs and Stratton web site and to the upper right corner of the page, enter your engine model number, 31p777, when following page comes up scroll down to match with the type number, 0296E1, then you will be able to view all supported materials, this will get you to a screen to download operator's manual and an illustrated parts list.
If you have any more trouble with this just let me know and I will get you straighten out.
If you found this post to be really helpful, please rate four thumbs up.
SOURCE: Replacement part for Craftsman 650 Briggs & Stratton 22" multi cut mower Model #917.376741
the drive cable broke so i ordered a new one. looking for a answer on how does it connect to underside of mower and the top of mower deck ?
22'' 650 model no.917.376741. thank you.
