FOUND MY AMANA AQF1613TEW AT 37 DEGREES. COMPRESSOR WARM BUT DID NOT SEEM TO BE RUNNING. COPPER COIL COLD. PER TROUBLESHOOTING GUIDE PULLED PLUG. EMPTIED FREEZER BECAUSE IT WAS 12 DEGREES OUTSIDE AND SET CONTROLLER TO QUICK FREEZE. AFTER HALF HOUR PLUGGED BACK IN AND COMPRESSOR STARTED BACK UP. TEPERATURE WENT FROM 40 DOWN TO 33 IN A HALF HOUR. SET CONTROLLER TO 4 SETTING AND I WENT TO BED. NEXT MORNING COMPRESSOR RUNNING BUT ONLY 35 DEGREES. ANY IDEAS AS TO PROBLEM AND WHAT SHOULD I CHECK NEXT.
You need to check to see if the compressor is running when the system starts getting hot. Issues that are going to make it it warm are as you said, a compressor failure, but it could also be a condenser fan sporadic failure, dirty condenser coil, or even a partially capillary tube.
Also check you evaporator coil on the inside of the refrigerator when it gets warm. If the evaporator fan fails. You'll have no air flow across the coil and once it freezes over, you will lose any convention cooling you had and the box will get warm and the ice on the coil will continue to grow
I'm leaning 2 directions, one is that your tstat is sensing your heatpump can not keep up with the load. Therefore bringing on heat strips or two, you have a cycles per hour limit set for compressor heating and your machine is cycling too often.
If that fan stopped your compressor overheated, shut off on thermal overload. Carefully cool compressor with water hose and restart. If the big copper is cold ,small copper warm, compressor is running. Check capacitor on compressor
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Lubricate the condensor fan with a parifin based oil like Union 76 turbine oil or "Zoom Spout" oiler. These fans are notorious for the bearings drying up on them.
Being careful.... touch the compressor copper lines. One should be very warm almost Hot to the touch.
Also with the unit unplugged..... note that there is a coolant drier with a small capillary tube coming out of one end. Tap the side of this by holding a hammer handle (wood) against it and hit it on the side with a screw driver handle.
Check to make sure the evaporator fan in the freezer compartment is also running when the compressor is on. Anytime the compressor is running BOTH fans must be running. If you can not get the condensor fan up to full speed you will note that the chassis around the door seal area will be quite warm almost hot to the touch and the unit will not be cooling properly. Just for troubleshooting.... direct a fan at the condensor coils and see if the freezer compartment gets cold and that the chassis around the door seals is just warm.
Note about compressors in general.... if you unplug a unit.. it must settle / stabilize for 15 - 20 minutes so that the compressor can restart. Any power off periods less than 15 mins will result in the compressor cycling via the thermal overload every 4 minutes or so... and it does not run for more than 40 seconds when the overload kicks off the PTC relay power.
If you never feel the copper line off of the side of the compressor get hot then the unit has lost coolant.
If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Hi, As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips. If your refrigerator is running but warm, then… Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
