I bought new eye glasses from a reputed optometrist in Sept. 2017. The nose pads slip down very often. I can't see flat LCD TV screen good or read a book. I have to lift my eye glasses to the top of my nose every time they slip down. PLEASE SUGGEST GOOD SOLUTIONS!
SOURCE: Flickering tv screen when playing playstation games.
I don't think it's a configuration problem at all. I do think that the set is not adjusting to the correct format. Most Stores have 30 day return policy. If it's over 30 days then they may not take it back. If you bought it online, then, the return may be difficult. If the return is not possible, then, contact Toshiba online and find a local Toshiba authorized servicer in your area. Hope this helps.
SOURCE: LCD TV with broken screen, good picture??
You can have them repaired using a TV Repair guy but often it costs as much as a brand new plasma. My daughter broke my $1,600 LCD. It would have cost $1,200 to fix.. so I just bought a new one.After that I picked up a TV screen protector called TV Armor http://www.tv-armor.com Its designed to protect the TV from damage. Now I dont have to worry anymore when she is playing near it. It works really well.
Eric
SOURCE: bought Niko 32 LCD HDTV last year Sound is good No picture.
Changing the inverter board shouldn't be hard. It's just the matter of taking things apart and unplugging some wires to it.
There shouldn't be anything you would have to solder in.
I'm sure he gave you the price of the whole inverter board itself. Not the small transformer inverter on the board.
SOURCE: LG LCD flat screen TV - 42LG50-remote control is unresponsive
Sounds like a probable main board issue
SOURCE: LG RU-42PX11 42 plasma TV has black bar
it seems to be a bad connection somewhere but I disconnected the ribbon cable and got a verticle line of snow instead of a blank line. the line is about 34 mm wide and starts 285 mm from the left edge starts on the Blue and goes to the Red pixels. so if they are 1mm wide that would be 34 bands of color.
I would sure like to figure out the solution to this one or I got a TV I need to throw away cause the o'lady is gonna bust my balls if I can't fix this!
