For the Owner's Manual and information on your Amana, go here:
http://owners.amana.com/user-manuals/
Good luck.
Thanks but that just tells about how to set up an possible causes, but thank you
No Dennis, there is also a parts list included for your Amana, go here:
https://www.amanaparts.com/Shop-For-Part...
Good luck.
Dick your comment matches your name - if you wouldve viewed the parts page you see theres neither a belt nor a direct drive coupling for purchase. From my research Dennis, if your amana is like mine its a whirlpool and has a direct drive as mentioned below - and much easier repair than a belt.
Yes it does
SOURCE: How to change drive belt on Amana washer
remove the 4 bolts holding motor to tub and frame remove wire harness from motor remove pump hoses turn assembly upside down 3 torx screws hold pump to motor note routing of old belt around idler pulley and pump studs reinstall in reverse
SOURCE: washer belt
To replace the belt on your Amana washer, pull the unit forward then tilt the top of it back to about a 45 degree angle. Once you get the right angle, the unit will rest against the wall behind it instead of falling forward. Take your new belt (availble through local appliance parts stores or on line from the manufactures web site) and first put it in the track around the large pulley, then the track on the smaller pulley on the right. Lastly, the pulley on your left should be moveable. Move the final pulley so that you can get the belt over it. It will then move back to a tensioning position.
SOURCE: AMANA WASHER WON'T SPIN. HOW DO I REPLACE THE BELT?
is this a whirlpool built amana? if so, its most likely a direct drive model, and when it doesn`t spin its likely a coupling between the gearcase and motor assembly...youtube has videos on how its replaced, which isn`t too complicated to do...good luck
SOURCE: I have water coming from the bottom. How do I take
remove the 2 bottom front panel screws-mike
