Hello, Joseph -
I hope I am safe in assuming you are asking about a Stanley cordless rechargeable spotlight. If so, according to the owner's manual I found through the Stanley tools home page:
(Link to the owner's manual):
https://docs.wixstatic.com/ugd/217982_ae7e48e26fee4748ab08acf8435c8efc.pdf
on Pages 4-5 of the manual, starting at the bottom of Page 4 and continuing on the top of Page 5, it states:
Therefore, depending upon the charging source the recharging will take between 5 to 20 hours.
Note: Your question landed in the category of Computers & Internet.
SOURCE: battery not charging
most probably you have an IC problem have a licenced repair man to check on it.
SOURCE: power connector of T40 think pad loosen
if you think your adapter really works fine then you have a motherboard issue.
SOURCE: my laptop turns off when i use it on ac power
had the same problem several times...used compressed air to blow dust out from inside notebook. I think toshiba hadan issue with this model and never fixed it...was also a class action i believe.
SOURCE: the battery can not use without AC adapter
The Batery is defective.
From the moment the first charge is begun, the power charger cannot be disconnected for around eight hours. If it is, the battery will only keep a partial charge.
Chances are the first charge was incomplete, and the battery will no longer retain a full charge. This could be caused by you, or perhaps a previous user of the battery. If you can return it for a NEW replacement, do so, otherwise you'll have to buy a new one.
Note: New laptop batteries can run for two and a half hours at best, between charges. Litium Ion batteries do not do well if they are left uncharged, but will recover after repeated charges.
SOURCE: have a stanley tre550 and need to know how to use
The staples are NOT loaded on top of the pull out shaft; they are inserted directly into the slot that opens when you pull the shaft out. If the nose of the tool is not placed firmly against a surface, it will not fire. Go to Stanley’s website’s knowledge base and type in the model number, and you can get a PDF of directions. http://www.stanleytools.com/default.asp?TYPE=STATICLEFT&PAGE=Support.htm&LEFT=left_support.htm Below is the graphic from their pdf. Here is a step by step: Unplug the tool. Squeeze the end of the shaft at the rear bottom of the tool and pull out the shaft. Flip the tool over on it’s back. Insert the staples, (points up) and then slide the shaft back in. Plug it in, press the on button (under the the power cord in the back). Press the nose squarely against the material and press the trigger.
• IMPORTANT: This unit is delivered partially charged.
Plug into an extension cord FOR 40
hours before using.
You cannot overcharge the unit using the AC charging method.
• To recharge this unit, use only the supplied AC charging adapter.
• All ON/OFF switches should be in the OFF position when the unit is charging or not in use. Make sure all switches are in the OFF position before charging. Here is the instruction book:
http://ecx.images-amazon.com/images/I/81US%2Bom6xKS.pdf
here is the booklet.
