Question about Mini Audio Players & Recorders
Trying to set clock on on mini stereo system and do not have remote
    Genius:
  • 1,691 Answers
You need the road only. Or you can try to find a universal rote that can work. Logitech have some universal types that may work. Check it it.
Posted on Jan 04, 2018
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 74 Answers
SOURCE: Trying to set clock time
http://resources.jvc.com/Resources/00/01/15/GET0582-
001A.pdf
you will find the instructions on the link above
Posted on May 12, 2009
marceds5012
SOURCE: HOw do you set the clock on an RCA RP9328A stereo without remote?
I have this system. According to the manual you have to do the following. 1. Press and hold the TIMER/CLOCK button until CLOCK appears in the display under the time. 2. Press the SET button once and the hour will flash. 3. Use the << or >> buttons to ascend or descend to the correct hour. 4. Press the SET button again and the minutes will flash. 5. Use the << or >> buttons to ascend or descend tot he correct minutes. The time will flash for a few seconds and be set when it stops. I have tried those steps and you may have to do them a few times in order to get the time right. It's a little tricky. I haven't bothered to reset the time as I have other devices that display the time without the back and forth with this device. It's a nice system and the sound is okay for my purposes. Hope this helps.
Posted on Jun 28, 2011
How do I set the clock on my Panasonic SA-Ak270 mini stereo
The main unit is the SA-AK270. The entire mini-system is called the SC-AK270. The manual is available on the Panasonic support site: https://www.panasonic.com/au/support/manual-download/audio/hi-fi/sc-ak270.html . You do need to accept the Panasonic terms of use to download the manual. The check box is below the box with the Manual description and View link. The clock setting procedure is shown on page 14 (with the remote). The pictures of the remote control and main unit buttons are on pages 8-9 of the manual.
With the remote, press the Clock/Timer button until the Display is showing the time. Press Skip Back/Rewind or Skip Forward/Fast Forward within 8 seconds of pressing Clock/Timer to set the hour. Press Clock/Timer again and use the same Rewind/Fast Forward buttons to set the minutes. Note: the SC-AK270 uses a 24-hour clock.
You can also do this by starting with the Display button on the main unit. Then use the Skip Back/Rew and Skip Forward/Fast Forward buttons on either side of the Manual Eq button.
I hope this helps.
Mar 07, 2018 | Panasonic Audio Players & Recorders
How do I set the time on my Panasonic stereo system sc-en17 without the remote
Unfortunately, the clock feature is only accessed with the remote control on the Panasonic SC-EN17 with the Clock/Timer button. The original remote model number is EUR7711170. Amazon has a replacement remote here: https://www.amazon.com/Panasonic-EUR7711170-REMOTE/dp/B001TISTZ0. It's $24. The manual for the micro-audio system is available on the product page: http://shop.panasonic.com/support-only/SC-EN17.html . The direct link to the manual is currently ftp://ftp.panasonic.com/audio/om/sc-en17_en_om.PDF . Setting the time is shown on page 5.
I wish that I could provide a better solution. I hope this helps.
Feb 18, 2017 | Panasonic Audio Players & Recorders
How to set clock on onn mini stereo system
There are several onn mini stereo systems. Suggest you google onn stereo mini system, as there are several user manuals available. Select the one for your model & look for clock instructions
Jan 21, 2017 | Mini Audio Players & Recorders
Got a Panasonic CD stereo system SA-AK410 When I turn it off after a few seconds it turns back on. Is this normal?
That's because you haven't set the clock on the system. I jumps to DEMO mode once you turn it off without the clock set. Clock can be set through your remote. Hope this helps. Cheers.
Oct 04, 2013 | Panasonic Remote Control Eur7710020...
  • Use the actual stereo to set the clock, not the remote.
  1. Turn off the stereo.
  2. Press "clock/timer" for at least 2 seconds.
  3. Press "memory" to make the hours blink.
  4. Turn the volume knob to adjust the hours.
  5. Press "memory" to make the minutes blink.
  6. Turn the volume knob to adjust the minutes.
  7. Press memory.
  8. Now the clock setting is complete.
Regards, Tony
May 21, 2011 | Sanyo AWM-660 CD Shelf System
I just got a 2002 Mini Cooper and can't seem to
other than finding a station and holding the button in til it flashes
Mar 04, 2010 | 2002 Mini Cooper
Need to set clock on jvc compact component stereo amp
How do I set the clock on my jvc compact disc audio system. model # KD-G110
Oct 21, 2009 | JVC MXKC4 360-Watt Compact Component Audio...
How to set clock on Sharp XL 1700 stereo
When the system is off take the remote and press the clock function. After the system lights up press and hold the memory button on the remote. Then press preset up or down to change hour (cycle through 12 hours to change AM PM). Then press the memory button again to change to minutes and repeat.
Jul 30, 2009 | Sharp XL-1700 CD Shelf System
Mar 14, 2009 | RCA Audio Players & Recorders
Clock set instructions for Sanyo stereo awm2800U
you need the remote to change the clock press timer am 1200 blinks press timer again for at least 2 seconds the hour blinks press tuning/time set plus or minus press clock adjust the minute will blink press time set to adjust minutes then clock adjust there you go...
Mar 10, 2009 | Sanyo AWM-2800 CD Shelf System
332 people viewed this question
Top Mini Audio Players & Recorders Experts
 Mike M
Mike M
Jerry Greenberg
Jerry Greenberg
Are you a Mini Audio Player and Recorder Expert? Answer questions, earn points and help others
