SOURCE: Landice L7 gives me a L5 reading on the screen
Your L7 error looks like L5 , but its really LS which mean lost signal. Unplug unit take motor shroud off then plug unit back in wall outlet. When looking in front unit you will see a Motor control board and there are LED lit up one of them should be an amber light this is you speed sensor which is attached to the top of your motor. Manually rotate the fly wheel and see if that light flickers if it does then your speed sensor is working properly if not replace speed sensor. The next thing to look at is the motor brushes to if they are worn unplug unit you should see slitted caps on both side of motor remove them if they are less than 3/8" they need replacing. That for the most parts should take of your problem. Call Landice @ 1800-526-3423 have the serial# handy their on all the components in the unit
SOURCE: Landice L7 ce error code
Dear Sir:
This condition indicate problem with the elevation motor.
You must Run the software calibration, for easy diagnose and troubleshooting, see your user manual
Try to clean and lubricante the elevation motor, gear and the shaft of motor.
sincerely.God bless you.
ernesto cuadra
managua, nicaragua.
