Drills Logo
a
abooysen Posted on Jan 03, 2018
Can one recharge ryobi bat1860x battery with the xpp 2700 charger?
Abdullah Samuels
Level 1:
New Friend:
  • Contributor 30 Answers
  • Posted on Jul 11, 2019
Abdullah Samuels
Contributor
Level 1:
New Friend:
Answers
30
Questions
0
Helped
9101
Points
84
You have to ask the store owner where you purchased it.
5 Related Answers
Jim Thurston
  • 672 Answers
  • Posted on Jul 04, 2009
SOURCE: NEED A MANUAL FOR A RYOBI BATTERY CHARGER
This link should help in finding a manual. Good luck. http://powertool.manualsonline.com/manuals/mfg/ryobi/ryobi_battery_charger_product_list.html
Nick Olsen
  • 196 Answers
  • Posted on Jul 29, 2010
SOURCE: Do Ryobi rechargable batteries fit other brand rechargers?
they dont fit at all
Anonymous
  • 8 Answers
  • Posted on Nov 18, 2010
SOURCE: We have a Ryobi P100 Battery and a P110 charge.
It sounds like you drained the batteries down as far as they will go. This happened to me and then I purchased the 18V Lithium-Ion battery and charger. I was able to re-charge the drained battery on the new charger. This may work for you as well. They cheapest solution for you is to just purchase a new battery.
Anonymous
  • 2176 Answers
  • Posted on Jun 16, 2011
SOURCE: I have a Ryobi set
I checked a couple sites and would suggest calling RYOBI parts supplier at 1-877-545-4099 to ensure that you get the correct charger. They might ask you what the model nnumber and the voltage and type of battery so have these numbers handy. Let me know if you need more assistance.
H2_Brad
Brad
  • 425 Answers
  • Posted on Aug 25, 2012
SOURCE: will a ryobi 18 volt charger replace a coleman powermate battery charger?What's your problem?
They look different in their shape where the battery goes so I would say no. To be safe always use the charger from the same manufacturer. There are a few different types of batteries too so it is always best to use the model number of your original charger to search for the replacement.
Why would I have no light on my 14.4v cordless drill battery recharger
Depending on the model number of the charger, the light only shows whilst a bettery is connected.
2helpful
2answers
1helpful
Is there a method to bring power tool batteries back to life?
Yes! Rechargeable batteries can be rejuvenated by draining them fully and then recharging fully and then repeating a few times! The trick is to fully drain and fully charge!
2helpful
Included in my Ryobi printed instructions are the statements: 1-"Green LED on indicates battery pack is fully charged and charger is in maintenance charge mode. 2-"To obtain the longest...
Any battery left in a charger is still hooked up to a circuit. Depending on the charger this can mean a slow discharge is possible. Ryobi's Maintenance Charge Mode means the charger will 'refresh' the battery at regular intervals, usually every 30 days. A battery's lifespan is determined by how many times it is discharged/recharged so to get 'the longest possible battery life' it is desirable to reduce the number of times a battery is recharged. One way is to use the battery until it is dead or near so another is to remove the battery from the charger when it's fully charged to reduce the number of times the charger refreshes the battery.
12helpful
Green & Yellow light on 14.4V charger
It sounds like your battery is bad.
If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
1helpful
HOW TO REPAIR YOUR RYOBI RECHARGABLE DRILL BATTERY
ryobi is the most inexpensive cordless brand, and they assume you will throw it out after it stops working so there is no repair support. sorry.
6helpful
Dead ryobi 9.6 volt battery recharge?
email me i will send you the instructions ,,its easy and it works ,,,to [email protected] cheers peter
2helpful
Lithium batteries?
Just got a reply from Ryobi tech service and it says that "all Ryobi 18V platform power tools can accept and use the lithium batterys, but you must use the charger for the lithium to recharge them. Hope this helps. Dave
Top Ryobi Drills Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
