Family alarm code E10 means difficulty in filling during wash phase or water leakage.
Could be:
E11 - Tap closed or water pressure too low; Drain tube improperly positioned; Water fill solenoid valve is faulty; Leaks from water circuit on pressure switch; Pressure switch faulty; Wiring faulty; PCB faulty.
E13 - Drain tube improperly positioned; Water pressure too low;
Water fill solenoid valve is faulty; Water circuit on pressure switch is leaking/clogged; Pressure switch faulty.
Dado
SOURCE: Err Err err err err pau
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
SOURCE: frigidaire (gallery series) err problem
Click on your model number (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
SOURCE: frigidaire affinity indicates 'err' light - nothing else
Dear Abhkss
ngfam at you service,
Sounds like you need service for electronic parts!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
SOURCE: WCVH6800J GE Front loader timer keeps resetting
The clock timer might be faulty.Need to Replace it.Since the machine is new, it must be under warranty and can be subjected to replacement.Problems with clock timers is common with any washer.Its better when detected early like in this case.Good luck.Please do post your comments.
SOURCE: have a kenmore front load washer and shows pau 45
LOC means it thinks the control panel is locked.
This gives the ERR indication when you push the buttons.
To unlock it you need to hold down the Options and Select buttons together until it reacts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
