Shuaib abdulganiyu Posted on Jan 02, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the problem of sharp AR-5618 if is too light but it was printing white horinzontal on the copy before
Tareq Bin Mostaq
Level 2:
Champion:
  • Expert 205 Answers
  • Posted on Jan 10, 2018
Tareq Bin Mostaq
Expert
Level 2:
Champion:
Answers
205
Questions
5
Helped
112274
Points
323
You should change developer & toner cartridge
5 Related Answers
Bubbabear64
Tim Babcock
  • 2794 Answers
  • Posted on Jul 20, 2008
SOURCE: my Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
Anonymous
  • 6966 Answers
  • Posted on Nov 17, 2008
SOURCE: Sharp AR-5320 Driver
Appreciate the direct "Ask Me". For Sharp AR5316/AR5320 drivers, pls click here. The drivers are for Windows 95, Windows 98, Windows ME, Windows NT, Windows 2000, Windows XP only.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Everett Lin
  • 990 Answers
  • Posted on Apr 28, 2009
SOURCE: sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
Anonymous
  • 175 Answers
  • Posted on Jun 23, 2009
SOURCE: H2 Error Message on AR M205 Sharp Copier
hi..there is a problem in the thermistor,thats why you
get the error code as H2.
check this out..
thank u..
kindly rate my response..
Anonymous
  • 212 Answers
  • Posted on Mar 06, 2010
SOURCE: Sharp AR-M160 A3 Printing
You need to contact Sharp ! !
They are the ones who developed the new Windows 7 drivers and now they are defective! Call them back (Sharp), and tell them they need to give you a new driver that will fix the A3 issue of your printer.
1helpful
Sharp AR 5618 Inconsistent Fade Lines
First portion of your problem seems to be caused by Printer Cartridge. Second portion seems the fault is in the scanner.
Refer to section 8 of Service Manual
Download Sharp AR-5618 Service Manual ' ManualsLib
My sharp ar 5618 is making light photocopy
change the drum and or transfer seperation roller or the transfer belt.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Total counter reset program for sharp ar 5618
Can not be done. people then would reset the counters on old machines and sell them as new
1helpful
2answers
Light copy IN SHARP ar 5618d
I have a problem on sharp copier ar-5618 it copy is too light but it was printing white line before
61helpful
4answers
1helpful
3answers
How to reset sharp AR -5618
how to reset the toner chip as it is costaly
F2-64 on sharp AR-5318
sharp ar 5618 zerox machine in f2 64 error solution
Sharp AR 5618S Error F2
Hope this help.
Hold down the copy start button
You will get F2 flash then 2 numbers will flash
http://www.manualslib.com/manual/902246/Sharp-Ar-5618.html?page=55#manual
5helpful
2answers
Sharp ar 5618 meter reeding reset
i want to change meter reading of sharp ar5618
My Sharp AR-M160 will print but not copy. No problem buttons are lit up but just dont work.
have you got the machine on print mode
if you find the button that says print copy fax on it press it until the light is on copy...
hope this helps
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
