Dryers Logo
A
Anonymous Posted on Jan 02, 2018
HOW TO FASTEN A LOOSE DORA CUSHON DRUM?
ONE OF THE TWO DURA CUSHIONS IS LOOSENED AND MAKE NOISE WHEN TUMBLING . THERE APPEARS NO ACCESS TO FASTEN IT.
Brian Main
Level 3:
Master:
  • Master 469 Answers
  • Posted on Jan 02, 2018
 Brian Main
Master
Level 3:
Master:
Answers
469
Questions
0
Helped
118176
Points
1988
They are attached from the outside of the drum. You will need to open up the cabinet to get to the fasteners
5 Related Answers
hotpoint jon
  • 353 Answers
  • Posted on Mar 20, 2010
SOURCE: loose part in drum area
unplug machine go to botton remove large outlat hose9attached to the drum and pump u can then work inside through the hole
Anonymous
  • 6 Answers
  • Posted on Jan 07, 2009
SOURCE: DRYER FIN IN DRUM IS COMING LOOSE
Unplug the dryer, remove the door hinge screws that go into the cabinet and the two screws on the opposite side of the door opening, then the front panel can be removedby starting at the top. Once the front is off, there are two screws, one to each side that hold the top on, remove these and raise the top. You can rotate the drum by hand and the baffles are held on by the screws on the outside of the drum. Reassemble in reverse order.
Anonymous
  • 145 Answers
  • Posted on Dec 21, 2008
SOURCE: tumbling vane screw came out
Hi and welcome...
You don't want to pry on anything, that top is secured by hooks and you have to do some dis-assembly to get the top open.
1. Open the door and remove the two screws that secure each of the door hinges to the dryer frame. With the door open so you can take a hold of it, simply pull the whole door out of the notches that the hinges fit into. (This is a reversable door designed for easy removal by the customer)
2. Remove the two screws on the opposite side of the frame where the door closes to. (along with the two white plastic trim pieces the screws go thru)
3. Once the door is off and the screws are out, pull the entire front panel forward and then it will lift off the tabs at the bottom and you can set it aside.
4. Look up near the top of the cabinet, on each side, for the metal hooks that secure the top to the cabinet. Remove the screw (5/16" nut driver) that secures each hook to the cabinet. Take the hook off, repeat for the other side.
Lift top.
Hope that helps.
A
Anonymous
  • Posted on Nov 04, 2008
SOURCE: Hotpoint Aquarius 1000.Makes noises when
Possibly the bearings have gone but check the nut on the pulley wheel has not come loose first.
Curt Downs
  • 1779 Answers
  • Posted on Sep 09, 2008
SOURCE: Whoopie cushon/balloon noise
Try disconnecting the air intake and see what happens (that won't harm the engine). I don't believe it will harm the engine w/ this noise, although it might be a little embarrassing. They have been using corn to make gasoline, I wonder if they started using beans?
Let me know the results and any new clues you may think of or the truck may develop. Have someone under the hood when u shut truck off to see it they can figure exactly where it's coming from. Beano in the gas tank? No, No, don't do that. countrycurt0
Beko DRVS6W tumble dryer squeaks when the drum comes to a halt
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
What could make a noise when drum tumbles on Fisher Paykel top loading dryer, Model DEGX2?
GOD IS GOOD !!!!
DRYER MAKES NOISES.
The blower:
The bearings:
Loose handle
Open the door and loosen the self threading screws around the sides of the inner door panel. Once this has been achieved lift the inner panel up so that you can access the door handle screws. Tighten these fasteners and reassemble the door panel.
How to replace ear cushion on bose QC 3 headphone
The ear cushions are held on the earcup with six snap fasteners, three on each side. To remove the ear cushion, simply pull it away from the earcup carefully so that you do not break the plastic snap tabs.
It should not be necessary to pry the ear cushion off with a sharp object, but if you do, be careful. There is also a thin gasket seal between the earcup and the ear cushion, take care not to damage it.
If you need to replace the ear cushions with new ones, they are available from Bose for $35/pair.
QuietComfort 3 Acoustic Noise Cancelling Headphones Bose Product Support
They are also available aftermarket at Amazon.com for $16.99/pair
Replacement Earpad ear pad Cushions For Bose QuietComfort 3 QC3 Headphones...
or $5.69/pair.
Bluecell Pair of Replacement Earpad Ear Pad Cushion for Bose Quietcomfort...
5helpful
Inside the dryer there are 3 bars that stick out to help tumble the clothes. One of them has come loose and I'm not sure how to tighten it. It appears to be attached with screws that come thru the drum...
With the front off look up in the top left and right corners for some screws that hold the top of the dryer to the side panels. Depending on your model, there can be different styles. The old maytags used 3/8 in screws up inside the corners and the newer models had 5/16 screws right up front.
Once you get the front of the top loose you will be able to lift it like the hood on a car to gain access to the drum.
Rotate the drum by hand to put your loose fin at the top and tighten up your screws. Sometimes the screws will round out the holes on the drum too much and you may want to put a washer on the screw to secure it better.
4helpful
2answers
Where are the fusebox locations on the 1996 caddilac sts
The fuse block is located next to the air filter on the driver's side of the engine. Lift the cover to gain access.
The Maxi-Fuses and relays are located next to the engine compartment fuse block on the driver’s side of the engine.
The rear fuse block is located on the front wall of the trunk behind the rear seat on the driver's side. Loosen the four trunk trim fasteners and pull the trim away from the fuse block to gain access.
For other details and description about specific fuse can check the 1996 Cadillac Seville STS - Owners Manual (page 314 and next).
Hope helps (remember comment and rated this).
Loud pop (sounded like a gunshot) during final spin cycle than heard constant noise. Does this sound like a busted bearing or belt? The tumble wheel is now very loose (easy to move and turn inside washing...
if the drum is very easy to turn with no resistance then the belt is likely broken and needs replacing. This is like changing the fan belt on a car where you loosen the bolts on the motor and hinge it towards the drum. Once the belt is in position, lever the motor back away from the drum to tension the belt and tighten the bolts.
1helpful
Chirping noise
Probably bad drum rollers. Or they need cleaning and lubrication. They are under the drum on the back wall of the dryer.Remove the front panel to access the rollers.
2helpful
Maytag dryer won't rotate after blower wheel replacement
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
3helpful
2answers
Whirlpool dryer drum making noise
window.google_render_ad();There are many places & parts that could be causing your Whirlpool dryer to be noisy. To find out what is causing the noises, you need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to pinpoint where in the dryer the noises is coming from. Once you have an idea of the area, you will need to disconnect the dryer from the wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of the drum, in other words, the baffles job is to separate the pieces of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot, the drum baffles holding screws will become loose. Loose drum baffles will cause noises. All you need to do, is to open the top panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the front and two on the rear. The job of the drum support rollers is to keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start to make squeaking noises and the roller bearing will start to wear out until the bearing on the roller is gone. When the bearing on the roller is gone, the noise will change from squeaking to a clanking noise.
The blower wheel:
The blower wheel is use to circulate the air inside of the dryer drum. The most common Whirlpool blower noises are cause by something falling inside of the blower housing and hitting the blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on the belt. There are two types of idler pulleys, the pulley with the wheel and the pulley with the teflon slide. A bad idler pulley could cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to run kind of noisy. When the motor starts making noises, the solution to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These belts work very hard making the drum tumble. When the belt stretch just 1/2 inch more that it supposed to, the belt will start slipping and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become noisy in your dryer. When your dryer starts making noises, make sure to check it out before it gets worse.
Top Dryers Experts
john h
