If the power light is on and the motor is not running the circuit board that starts the motor is defective. You could try to bypass the control board and apply power directly to the motor to verify the motor is ok and no blown fuse or circuit breaker. then you get to replace the circuit board or isolate a failing component on the circuit board.
SOURCE: Lights blink, but Cuisinart Smartpower 7-speed wont turn.
The thermal fuse is blown. You can buy a replacement from RadioShack for $1.69 You have to remove the old one and solder in the new one. If youre "handy" its very easy. Take it to a repair shop, you pay about the same as a new one. Its too bad that most electronics made today are cheaper to throw away and buy a new one rather than fix them when they break.
SOURCE: the lights on my cuisinart blender come on but the
Using your blade holder, turn the motor from the blade end. 1 or two turns. Tak the blade holder out, Plug in an test Sometimes the brushes in the mototor lose a good contact. SGood Luck -Ned-
SOURCE: Hi, my blender blades won't
when the blender cup is not on, does the spindle turn (medal stud looking thing)
and does it do it on all speeds?
SOURCE: My CB-600 Cuisinart Blender/Food Processor
Hello, gdvorak
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about blenders andpossibly yours, from repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances5.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
SOURCE: Cuisinart BFP-703CH Chrome Blender does not start
I had the exact same problem with my Cuisinart bfp-703ch blender. When I plug it in, the lights come on but the motor wouldn't run. After reading some posts I almost decided to throw it away. But my brain started to itch and I gave it a shot anyway. I eventually found the problem to be with the Thermal fuse. If you overload/overheat the blender, this fuse is going to blow off.
To replace it, I opened the bottom panel and followed the wires that come from the circuit. Once of those wires eventually will lead to the thermal fuse. It may help you if you unscrew the circuit board. Then I detached the fuse with pliers, got a replacement thermal fuse from Radioshack and connected it back on. I also had to solder it to make sure the connection is more robust. And Voila!!! my motor started working again.
