Do you get an error messsage that looks like LEr? If a Traeger can't reach 125 for ten consecutive minutes, it will automatically shut down. Try starting at a higher temperature than "Smoke" if it's cold outside. Traeger also makes "blankets" to help your smoker maintain temp in cold climates, but they're quite an investment.
SOURCE: I have an electric Traeger grill. I plug it in
Make sure your grill is unplugged. Them take the controler out and there is a fuse on the back side of the control. There is also a new fuse there to replace the old one. If the fuse is blown, you could have a bad hot rod or other component that is bad. Usually the hot rod is the problem and they should be under warrenty so call Treager and get a new one sent. If the fuse blows after it is replace, you can un hook the purple wire and replace the fuse and see if it will work them. If it does, it is the hotrod.
SOURCE: I turned off my grill
Whenever you finish using your Traeger it is always best to lift the lid and turn the controller down to the smoke setting and allow the temp to drop for a few minutes. This will also slow down the delivery of fresh pellets into your firepot thus starving the fire of fuel.Once the temp drops below 200 deg F than shut off the controller. If you have any wind blowing remove your Traeger out of the draft of the wind and the fire will go out on its own.
