Question about Science & Laboratory
Anythinng for Variscope Binocular microscopes
Operating/set-up manual for 40x 1000x binocular compound biological microscope
    New Friend:
  • 24 Answers
A User Manual for the Variscope Binocular 40x to 1000x microscopes is available from Amazon online:
http://www.manuallibrary.net/1475-40x-1000x-biological-binocular-user-manual.html
Posted on May 18, 2019
6ya staff
SOURCE:
Anonymous
  • 45 Answers
SOURCE: problem with MF-02 binocular microscope stage
I think your problem lies in the way the stage is limited upwards. On top of the stage, right behind it where it slides against the arm, there should be a little screw.  This screw limits the movement of the stage to a certain point upwards.  If the limit exceeds the adjustment gear and its opposing track, then the stage just goes up one notch and then it clunks down.  If you screw it down the stage is limited further down, if you screw it up it's limited a bit higher.  The point of this screw is to prevent objective and slide damage.  Try adjusting this little screw a bit further down and see if it still 'clunks' when you turn it up.  After that we may work on properly adjusting it.  If not, please post again with whatever detail you can provide to aid you with this problem further.
Posted on Jun 09, 2008
Anonymous
  • 43 Answers
SOURCE: Need operating manual of polarizing microscope
www.zeiss.com/C1256F8500454979/0/1890F238E9747195C1256F8F0032D082/$file/b-40-016axiolabpol.pdf
Try on this page.
Posted on Jul 21, 2008
clarke_kent_
  • 12 Answers
SOURCE: Is there a manual for this microscope? Motic B1 binocular
try www.manuals4microscopes.com
Posted on Apr 12, 2010
clarke_kent_
  • 12 Answers
SOURCE: Looking for a Citiwell microscope operating manual
Posted on Apr 13, 2010
Gomer Quitorio
  • 36 Answers
SOURCE: what is the other types
Compound Microscope
  • Compound microscopes can be found in most biology and science classrooms. They are electrically operated and use light to enhance the image of a cell. They will have multiple lenses for viewing.
Dissecting Microscope
  • Dissecting microscopes are also known as stereo microscopes. They have low magnification and are also light powered. These microscopes can view objects larger than what a compound microscope is able to handle, in three dimensions.
SEM
  • A Scanning Electron Microscope uses electrons instead of light to create an image. These microscopes produce three-dimensional images with high resolution and magnification. They also have a larger depth of focus.
TEM
  • Transmission Electron Microscopes use electrons instead of light to create an image. The material prepared must be very thin. The beams of electrons that pass through it give the viewer high magnification and resolution. These give two-dimensional images.
Posted on Jul 04, 2011
I have a really old edu-science binocular microscope set in a kit with many things to do but I don't have a manual telling me how to use everything in the kit. I can't find a model number.
I doubt if you will find a manual - if you can supply a list of the items in the kit, I'll endeavour to offer some advice, based on my school biology lessons of some fifty years ago !
Aug 05, 2017 | Edu-Science Optics
I just bought an OMAX 40X-2000X Digital Lab LED Binocular Compound Microscope with Built-in 1.3MP USB Camera but I can not install the CD with the photo software so I can not view these images on my...
I do not think so . Most image programs manipulate the image once the vendor software has taken the image Why can you not instal the software
Mar 03, 2015 | Science & Laboratory
How do I align Phase Contrast?
Open the field and the condenser diaphragms all the way. bring your object into focus then insert the telescope eyepiece which lets you see both phase rings. Bring both the phase rings into focus. Then move the phase ring of the condenser's side until it is lined with the phase ring of the objective and no light gets passed up. Inspect your object now with your regular eyepieces. That is it. Have fun.
Mar 02, 2015 | OMAX 40X-2000x LED Binocular Compound...
Mf 2 model - where do you put the cedar oil when using 100x magnifcation. i have read the manual and do not understand. i am a novice
The oil goes between the cover slip of the slide and the objective tip. It can also help to put some between the condenser lens and the bottom of the slide. Be careful when using oil, as when rotating to lower magnifications, it is very possible for the 40x to get oil on it. The 100x is sealed to protect it, but the 40x is not. If oil gets on the 40x, it can seep up inside and destroy the lens.
It is also a very good practice to clean both the 100x and 40x after each use. If the oil sits on even the sealed 100x objective for any long extent of time, it will start to break down the silicon seal, and you can potentially have the same problem as with the 40x, where the objective acts like a wick of a candle and sucks up the oil, thereby destroying the objective.
Jan 20, 2011 | Premiere Microscopes MF-02 Binocular...
How do I get motic microscope lens repair? It's an older model-a BA 200. Our lens is a EF Plan 40X objective /0.65 /0.17
You can send the lens to Delta Optical Instruments, Inc.They can determine if your EF Plan 40x objective lens is repairable.The will give you an estimate prior to work or suggest a replacement if it cannot be repaired.email them at:  robin@deltaoi.com
Oct 06, 2010 | Motic DMBA 300 Binocular Microscope
You should contact motic directly via http://www.motic.com/Sufeedback.aspx?r=NA&lang=en&email=info.education@motic.com and request the manual, though i don't see how a manual would be useful since the 220A is a pretty standard microscope.
Dec 26, 2009 | Motic B1-220A Binocular Microscope
Lightbulb was blew. Where we can buy
VWR, Fishersci, wardsci, carolina biological, etc. Make your pick. Enjoy.
Dec 08, 2009 | Advanced Electronic Support Baytronix ...
Science & Laboratory Logo
301 people viewed this question
Top Science & Laboratory Experts
Pokinhas
Tom Chichester
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
