SOURCE: Goodman furnace
sounds like the fan switch in the furnace is coming on and off. This is common for Goodman. or could be the heat anticipator on the t-stat. While there are several reasons this happens these are the most common.
Guy
SOURCE: Where is the reset button a goodman furnace? We
Try to turn the thermostate down or off for 5 min. and then turn it back on for a call for heat. This should reset it.
SOURCE: goodman furnace reset
should just have to unplug or turn power off to furnace for thirty seconds and will reset the control board and then retry.
You can reset the controls by cycling the power off and then on again...
There also is a reset by the burner and one by the blower...push in the little red button in the center on the limit switch...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
