Tablets & eReaders Logo
K
Kellie Stewart Posted on Dec 28, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can not get the tablet to recognize the sd card. I insert it, but I do not know what settings I need to go to in order to activate it.
Parshiv Luthra
Level 3:
Master:
  • Master 395 Answers
  • Posted on Dec 28, 2017
Parshiv Luthra
Master
Level 3:
Master:
Answers
395
Questions
Helped
86355
Points
1069
It should automatically recognise it. Reboot and check. Check with another memory card. if still does not work then mostly the connector on the tablet has gone bad
5 Related Answers
pkr9040
PK Rietz
  • 9 Answers
  • Posted on Apr 11, 2014
SOURCE: i inserted an sd card but my galaxy tablet 2 don't recognise it.
Try un mounting the sd card with the card installed then take it out and teinsert it If that don't work it could be the old format isn't recognized and try formatting it then
shadowchb
  • 268 Answers
  • Posted on Dec 04, 2014
SOURCE: i have an irulu tablet. I inserted a 32gb sd
Most apps do not natively install to an SD card when downloaded from the play store. You have to have an app like AppManager, that has a function to 'move' apps from internal storage to an SD card, or use a manual option in the Android Settings section to move each app individually.. If you are that tight on space that you cannot load any new app, you may have to delete or move something from your internal storage so you can download AppManager or some similar app, and then move as many apps as you can to your SD card. If you have a lot of photos and music you can try moving that to the SD card if your player/viewer software will allow you to find it there. Best way to move bulk items (music/photos, not apps) is to connect to a PC through USB, which brings up your internal storage and the SD card as external USB storage items. Then copy from internal storage to SD card through your PC. Best to establish folders on the SD card to hold these items and then tell your app where they are.
Team Techplus 2008
  • 143 Answers
  • Posted on Jan 13, 2015
SOURCE: How do I insert micro SD card into next book 8 dual core tablet. It does not show the SD card on systems.
Please see video below
Good luck
Testimonial: "Can't get video"
firefight49474
Dave Zuccarini
  • 6 Answers
  • Posted on Feb 19, 2015
SOURCE: put my apps on my sd card
Go to applications section under settings and click on the one you want and it should open up and there is a button transfer to sd card.
MotoGenius
Motorola Mobility
  • 3100 Answers
  • Posted on Mar 16, 2015
Mobile Phone and accessories
    Verified Fixya Pro
    SOURCE: Ok I have a zeki quad core tablet and a 8gb SD card and I'm wanting to download games from my tablet to the card how do I do it ? 2question once I do that how do I how do I synce them into my Motorola
    Brittaney
    You should download apps from Google Play Store to your phone. You shouldn't attempt to put them on an SD card. The play store ensures only compatible apps are installed.
    Mark
    Motorola Support
    RCA Delta Pro 2 Won't Read SD Cards
    It sounds like the tablet is having trouble reading your 128 GB SD cards.
    There are a few things you can try to troubleshoot this issue:
    1. Check the SD card for any visible damage. If the card is physically damaged, it may not work correctly.
    2. Make sure that the SD card is properly inserted into the SD card slot on the tablet. It should fit snugly and be fully inserted.
    3. Check that the SD card is compatible with your tablet. Some tablets can only support SD cards up to a certain capacity or with a certain type of file system.
    4. If the SD card was working fine before and has suddenly stopped working, it's possible that the card has become corrupt. In this case, you may need to format the card to fix the issue.
    5. If none of these steps help, you may need to try a different SD card to see if the issue is with the tablet or the SD card.
    How do I get the 7 in irulu tablet to see an SD card I put in the slot so I can move apps over?
    sd card is automatically recognized, however you need to
    - set default storage as sd card
    - also move apps and data to sd card from memory/storage setting menu individually.
    Yet many apps occupy main ram and refuse to release space
    How do you move internal storage to the sd card to free up internal space
    touch the "Settings" icon, go down to the "Device" area, touch the "Storage" icon : go to the bottom of the screen, and select "Transfer data to SD card", then select the items you want to move.
    You should also move some apps from internal storage to the SD card : "Settings", "Device", and touch "Applications" : then touch each and every application : for most of them, the button "Move to SD card" will be active, just proceed.
    1helpful
    2answers
    It will not recognize any SDHC micro card I put in it.
    you needto put 1 in and then go to settings an "mount sd card",for it to recognize it
    What to do after I install sd card
    Operate as usual. The tablet will recognize the SD card, and if you need to perform any activities, it will prompt you.
    Mounting sd card to a new phoenix hipstreet tablet
    Look in Settings/Storage/SD Card and see if you have a Mount option when you insert the card. Make sure the card has gone all the way into the slot and has clicked into place. Make sure the size of the SD card you are inserting is supported by your tablet. (Check the specs in the full manual) If the SD card is larger than what is supported, it may not register with the operating system. Try formatting the SD card on a PC with a card reader and then inserting it into your tablet. (Use FAT32 format).Try another formatted SD card and see if it is recognized by the tablet.
    How do I take a photo with an irulu 10" tablet.
    Just inserting the card does not activate it!
    go to settings and activate memory card.
    I inserted an sd card but my galaxy tablet 2 don't recognise it.
    Archos/7ob internet tablet how long does it have to charge innitionately?
    I find charging for 24 hours before use will yield the maxium capacity, after that overnight charge is fine. I would wait until tablet is activated before the sd cards are inserted.
    2answers
    Usb cd rom will not boot can i boot from sd card
    yes you must change the boot order and activate the legacy USB support if exsisted
    Top Tablets & eReaders Experts
    k24674
    ADMIN Andrew
    ADMIN Andrew
    Are you a Tablet and eReader Expert? Answer questions, earn points and help others
