SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
SOURCE: Washing machine front loading door won't open.
that is the way it's made you have to turn it off before you can open it or water would go every where.
SOURCE: LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
SOURCE: What causes "Error 4" to
Hi, googled this problem myself and found this page. Doesn't help much though. Will still have to get someone out to look at it.
http://kleenmaid-appliances.com.au/TSPM/WM/Kleenmaid/KFL1600_Fault_Codes%2040220415.pdf
Good luck, we'll need it now our warranties are useless.
SOURCE: My Whirlpool Duet Front Load Washing Machine is
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28
