SOURCE: battery life 10 to 20 minutes total
I went through many batteries as well. I found Duracell "PIX POWER". Made for cameras. Battery power is grat.
SOURCE: Why there are three wires in battery of Ton Tom one
You can get a multi meter from an electronic story really cheap.
It will tell you the voltage and the polarity of the battery connectors.
SOURCE: ALL Voltages (three wires) iones battery of Ton Tom one
Not sure why you would need to know this , red is live black is return circuit and the yellow is auxilliary and usually goes to charge input. as a live wire It is easier to cut and graft a new battery to the stubbs of wire than to solder new battery on. What you might really be needing is the polarity.. whether any charge pin is positive or negative if you are making a new internal charge point. Consult the back of the charger it usually states the polarity in a graphic.
SOURCE: No Power Using AC Power or Battery
I had this same camera. If you have a power fluctuation it can really damage the batteries. make sure it was not exposed to fluctuations
SOURCE: Battery Back Up receptacles no longer work
Your battery is either disconnected or failed and must be replaced.
