Wind line as instructed, when line gets low bumping knob does not work, have to take it apart to pull line from spool, then reassemble
Rewind the string. It probably crossed on itself and knotted up. Common problem
did that,i know twine can cross, therefor restrict line, but all three weedeaters?
If the Screw on Knob, that holds the Spool on is worn much, it makes a large difference too.
bought three new knobs
SOURCE: replace line in poulan electric weedeater model xt110 twist'n plu
Dear FixYa Fan, Friday 2-20-2009 10:44pm EST (USA)
RE: Poulan Lawn Trimmers
Poulan Lawn Trimmer FAQ @
http://www.ordertree.com/cms/Poulan+Trimmer%2c+Blower+%26+Edger+FAQ/241.html
Dear fitzknight: You will find instructions for putting line on your trimmer at this link http://www.ordertree.com/cms/Poulan+Trimmer%2c+Blower+%26+Edger+FAQ/241.html#changeline click on the http line preceding but please rate me 1st or come back and rate me before you close this or the Poulan Site!
Thank You,
jackiaria
SOURCE: Poulan 17'' Gas Weedeater keeps dying!
Hello su2yak2:
From your Description it Sounds like the Exhaust Port or Muffler is Restricted with Carbon Deposits, the Carburetor Metering Pump Actuator Gap is Incorrect.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
Is the Fuel Line from the Fuel Filter Staying Full of Fuel?
The Carburetor Metering Jet Actuator is Set so the Pump Diaphram Dowl is Just Touching the Actuator Arm. These Components are Located Under the Cover with 4 Small Screws Holdong it to the Carburetor Body.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: how do i replace a spool on the weedeater xt110
Just line up the two arrows across from each other to those on the the spool housing on the bottom of the spool. Then grip the bump knob and pull straight out. It takes a good grip and some force, but it usually gives way.
SOURCE: the pull cord on my poulan pro weedeater will not
You have a broken recoil spring. Dis-assemble (pull-off) the recoil housing and check for proper dog alingnment, broken spring, or something jammed between recoil sprocket and engine block.
