SOURCE: Connecting Computer to HDTV
If you use a graphics card with an S-Video output that allows you to connect to an S-Video input you can use that. Most computer graphic cards now a days come with an attachment that makes the S-Video output into a Component type connection which allows a 1080i image to be displayed on TV's. This is how I connected mine and you will have to mess with the color a bit to get it looking the way it suppose to.
SOURCE: My TV (42" Full HD
Yes you can - but not with a USB cable. USB is only for data (file) transfer.
What you are attempting to do is use your TV as a PC monitor, therefore it needs to be connected to your TV using a PC monitor cable (15-pin D-SUB/VGA). You will also need a separate audio cable from your PC to your TV if you want to use the TV speakers for audio. If you are using a receiver or amplifier with external speakers, you can connect the audio out from the PC directly to the amplifier/receiver.
It is also possible to connect the PC to the TV with an HDMI cable if your PC has an HDMI out port. However, some TVs wont accept an HDMI signal from a PC and this method of connection can cause other issues, so I would recommend using the PC monitor cable method.
Please let me know if you need further assistance.
Regards,
BElectric
SOURCE: how can you connect this tv to the internet, to
You have to buy an adaptor that "can" receive sat signal through your computer via wireless network. Netflix has several offers.
SOURCE: I am trying to connect
We are here to TRY to help you.
The thing we got to discuss is your router or access point. You need to update us with the make and model router.
Now if the thing is connected to the internet and you need a netflix code you need to login to your account via netflix.com then add a device after witch a code will be distributed.
So this could be a two part issue but from what your saying it looks to me if you need a WEP key and that would be found in your router or access point via 192.168.1.1. or 192.168.1.254. It would be hard for me to tell without the make and model of the router to tell you how to get this running.
Please update us with this information.
Thanks,
Edwy aka rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
