SOURCE: Kerosene Portable Forced Air heater comes on, runs awhile
Here is a link to your owner's manual... http://12.153.20.74/manuals/123919-01A.PDF. Look on page 8 and 10. It could be several things. It could only be a dirty fuel filter or the pump pressure may just need adjustment. If you need a part you can contact Master Parts at 800-466-1446 or you can find them on-line at www.masterparts.net. I hope this helps!
SOURCE: all pro heater runs for a couple of minutes.then
it only shuts down because of an overheating condition or the lack of fuel. if you have an ohm or multimeter, check the ohms on the fan and see if you have any resistance. If you do the fan is good but may still not be putting enough air across the heat exchanger to safely alloww the heater to run without causing a fire.
SOURCE: r100 reddy heater, low pressure forced air heater.
The R100 is a kerosene heater and the RLP100 is a propane heater so I am not sure when one you have.
If it is kerosene then you may need to check the pump pressure. Also the Safety swith can give you a cut out after 30 seconds.
If the unit is Propane then you could have a bad control board or a flame sensor.
You can call our service department at 1-800-475-5660
Thanks
Testimonial: "thanks! it is the kerosene heater. i ordered the low pressure gauge and will check pressure. motor cuts out and you hear the safety switch click."
Here are a couple of tips that I
wrote that tell you how to troubleshoot a Torpedo or Reddy
heater...
Reddy
Heater - Troubleshooting Torpedo Heaters
Torpedo
Heater Pump Pressure Adjustment
heatman101
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
heatman101
heatman101
