Food Processors Logo
A
Anonymous Posted on Dec 15, 2017
I purchased a Robot Coupe R101 and wanted to add the Pulse button. Do I just get a R101 Plus switch and front panel? How hard is the replacement? Thanks
R SHOAIB
Level 3:
Master:
  • Master 567 Answers
  • Posted on Feb 24, 2023
R SHOAIB
Master
Level 3:
Master:
Answers
567
Questions
0
Helped
80919
Points
1019
To add the pulse button to your Robot Coupe R101, you will need to purchase the R101 Plus switch and front panel. The replacement is relatively simple and can be done by following these steps:
  1. Turn off and unplug the Robot Coupe R101.
  2. Remove the screws that hold the top cover in place and lift off the cover.
  3. Locate the control panel on the front of the machine and remove the screws that hold it in place.
  4. Carefully remove the control panel and disconnect the wires from the old switch.
  5. Install the new R101 Plus switch onto the control panel and connect the wires.
  6. Replace the control panel onto the front of the machine and secure it in place with the screws.
  7. Replace the top cover and secure it in place with the screws.
Once the new switch and front panel are installed, you will have the pulse button on your Robot Coupe R101.
4 Related Answers
Capt Rick
  • 81 Answers
  • Posted on Jul 25, 2009
SOURCE: how do i seperate the housing on a robot coupe processor
There are 4 rubber shoes on the bottom of the white or gray base. Twist & pull these out. With a TORX long shank screwdriver (nothing else works, trust me) there is a screw way down in each hole. After removing the screws a gentle but firm bump should loosen the base. If you ever need to replace the motor, on the top around the drive shaft you will see three round plugs/disks, remove them by prying up with a pocket knife (works best) this will give you access to the three motor bolts.
Capt Rick
  • 81 Answers
SOURCE: How do I assemble the Robot Coupe R 2 Ultra
Cindy,
Send me your e-mail & I will send you back an exploded view of your Robot-Coupe. It will give all the info needed. [email protected]
Anonymous
  • Posted on Jan 06, 2010
SOURCE: I have a Robot Coupe R2 food processor that quite
It just a long shaft phillips screwdriver. The screws are located under the foot pads. They just pull out and then there are the four screws.
eugbug
EugenesDIYDen
  • 479 Answers
  • Posted on Jul 15, 2011
SOURCE: Where in ireland can i purchase a blade of my
You may be able to get it here:
http://www.nisbets.ie/products/AdvancedSearch.asp?keyword=cl30&x=64&y=5&PageSize=50
The part isn't listed but if you ring them they might be able to order it in.
Robot coupe 3b wiring diagram
Wiring diagrams are in the back of the manuals after the parts lists.
https://www.partstown.com/robot-coupe/blixer-3b/parts#id=mdptabmanuals
1helpful
I have a robot chef food processor it says type RC3 on the bottom the clear plastic top about 20cm dia with the funnel has broken where can I get a replacement part please?
To the person wanting a funnel for her robot chef just bought an old processor on eBay to replace the bowl I've got the lid if you still need it
2helpful
1helpful
Looking for spare parts for a Robot Coupe R301 Ultra Food Process
Robot-Coupe USA.com should be able to sell you anything needed
1helpful
Robo coupe CL52D would not turn on
There is a reed swich (safety switch) located on the top where the lid comes down. A reed switch works with a magnet. If the magnet is missing or the reed swictch is bad, no power will be allowed to the motor. Send me your e-mail & I will look up the part # in my Robot-Coupe manual. [email protected]
Robot coupe maintanance
That plastic piece is a sling disk or sling blade and made to sling product to the discharge chute. Believe it or not, the motor shafts wear out and could be the cause of premature failure. When you install the new sling blade, check to see how much slop/ play there is by moving this back and forth on the shaft, a small amount is ok (1/16th to 3/32nds). The other thing to look at is forcing or overfeeding the unit. You can contact them at Robot-coupeusa.com
2helpful
Cindy,
Top Robot Coupe Food Processors Experts
ADMIN Andrew
ADMIN Andrew
john h
ADMIN Eric
ADMIN Eric
Are you a Robot Coupe Food Processor Expert? Answer questions, earn points and help others
