I flushed my heater core by taking the heater hoses off the heater outlet and inlet and taking a garden hose and run water under low pressure for about a minute on both hoses going into the heater and mine cleared right up. Good hot air after that. I had to take some anti freeze out of the rad so I wouldn't loose fluid when I took the hoses off. This worked for my car.
SOURCE: 93 ford festiva heater only blows cold air.
The heater only blows HOT air when set on defrost or floor settings. If you have the lever set for vent, only cold air will come out. Check to make sure you set the controls to floor or defrost. This is standard for all Festiva's.
SOURCE: heater blows cold air have replaced the thermostat
sounds like the controller went bad use temp checker see what your temp is at inlet of heater core from hose
SOURCE: how do you flush out a heater core in a 2002 ford
No reason to. It is normally flushed out all the time by normal use. Sediment builds up in the engine and radiator, not heater. If the heater not getting hot enough, it is most likely the engine thermostat or the heater control valve. When you start a cold engine, the main radiator hose to the thermostat should stay cold for about 5 minutes, until the engine is totally up to temperature. Only then should the thermostat open and allow that hose to instantly get hot. If it slowly gets warm, then it is stuck open and needs replacement.
SOURCE: Have no heat. Have replaced heater core,
I don't know your vehicle, but does it have a blower door tucked in where the heater core is? If it DOES and that's broken then it could be the whole problem. It would mean it isn't switching from the A/C side of things to the heat side of them. Hope this helps, good luck! Also, just looked up the proper name for what I'm talking about, it's called a "blend door" and I think your car has one. It's what I would check, again, good luck!
SOURCE: flushing the heater core
I removed the hoses and took a air nozzle at low pressure and blew in the return hose connection of the core. A big chunk of paste like substance shot out then pure liquid. I put the hoses back on and tested it. Now its blowing hot!!!!!!!
