Hey buddy,
Its not that much big problem. You can easily fix it by following few simple steps. I was also facing the same problem. Then I came across an article, It really helped me to get out of this issue.
You can also read the blog and follow the same process: https://www.microsoftwindowssupportnumber.com/blog/fix-activation-error-code-0xc004f074-windows-8-8-1/
SOURCE: windows activation error code 0xC004F058
Quick search got this answer:
Step set #1
1) Open Internet Explorer
2) A Browser will open, type: %windir%\system32 into the address field
3) Find the file cmd.exe
4) Right Click on the cmd.exe and select Run as Administrator
5) Type: cscript slmgr.vbs -rilc (It may take a long time for this to complete, please be patient)
6) Hit the Enter key
7) Reboot 2 times
Step set #2
1) Open Internet Browser
2) Type %windir%\system32 into the browser address bar.
3) Find the file CMD.exe
4) Right-Click on CMD.exe and select Run as Administrator
5) Type: net stop slsvc (it may ask you if you are sure, select yes)
6) Type: cd %windir%\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\SoftwareLicensing
7) Type: rename tokens.dat tokens.bar
8) Type: cd %windir%\system32
9) Type net start slsvc
10) Reboot Twice
11) Windows Vista may require you to enter a Product Key [use the Certificate of Authenticity (COA)] SLP Product Key found on the sticker on the side or bottom of your computer and activate. Use the Activate by Phone method outlined below.
From the Desktop:
a) If you have access to the Start button: Click the Start button, and type in "slui.exe 4" in the search field and then press the "Enter" key. This will bring up the Activate by Phone dialog window. Follow the steps provided by the window. The phone activation process should only take about 6 minutes.
b) If you do not have access to the Start button: Reboot and login to Vista, a dialog window will come up. In that window, click the option "Access computer with reduced functionality". Once you do that, Internet Explorer or Firefox browser will open. In the address bar type "c:\windows\system32\cmd.exe" press enter, a new window will come up, type: slui 4 and hit enter and follow steps to Activate over the Phone.
This all is if you have a true bought copy of Vista. If you have a pirated version, Im sorry to say I cant help.
SOURCE: error Code: 0xC004F074
The steps below will help you fix the problem easily.
1) Open cmd(command prompt) with administrator rights
2) Type slmgr.vbs -ipk xxxxx-xxxxx-xxxxx-xxxxx-xxxxx (x should be replaced by your 25 digit product key)
3) Hit enter
4) Type slmgr.vbs -ato (This will change the product key)
5) Hit enter
