If engine is turned on then turned off, power steering fluid in reservoir is empty. WHile engine is on, theres a whirring kind of noise.
SOURCE: Suddenly leaking power steering fluid, reservoir empty
The best bet is its trans oil. The gearbox has crushable washers/gaskets, the bolts may just need to be tightened slightly to crush the gasket and seal.
SOURCE: terrible noice when I turn the steering wheel on my 2001 BMW 325i
Make sure you check your power steering fluid... if it's even low, it will make a terrible noise...run it on empty too long and your can ruin your power steering pump.
SOURCE: Where is the Power steering Fluid located?
This is what it looks like:
THERE IS NO CAP TO FILL IT LIKE NORMAL POWER STEERING SYSTEMS. IT HAS TO BE SERVICED FROM THE INLET HOSE.
Look underneath the car up at the driver's side of the car above your tie rods (or look at it from above). It is mounted to your steering gear.
SOURCE: power steering fluid foams up in reservoir, and
you need to replace power steering box the wheel inside is bad
