SOURCE: Kenmore refrigerator door will not close completely
Both top and bottom doors will not close on mine
SOURCE: Freezer works fine, fridge don't
your inside fan has stopped working. Could be stuck or frozen or simply bad.
SOURCE: freezer door hard to close
Any adjustment is at the hinge, you probably find that you have fitted it too close and it is pinching the gasket in the corner. Tilting the fridge back can help, but the doors must be able to swing closed freely first. This can be done by adjusting the footing screws below the front of the fridge.
SOURCE: Kitchen Aid Superba - door needs adjustment
there is two bolts oin the very front of the unit behind the kickplate the oiu can turn clock wise until there is a slight tile toward the back of the unit so that the cams on the doors will have a little bit of gravity to helop them stay shut.
SOURCE: Refrigerator door does not stay closed.
is there a sllight tip to the unit 1/4 of an inch towards the back to assist in closing the doors and keeping them shut.
