SOURCE: AV1 / AV2 Connections don't work
No picture or dark picture
Check R516 (56Kohms, 0.5w) or R517 (27Kohms, 0.25w) for high
Will not come out of standby, no picture
If at power on voltage on pin 37 of the micro drops low then reverts to 5v suspect memory chip ICA07 (Toshiba 23319016)
No picture No sound
Faulty IC TDA6107q on crt board
No picture on e-e, I.F output ok
This was due to switching chip IC3901 (M51292FP) on the scart panel
SOURCE: Samsung 40" Full HD LCD
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
SOURCE: How do I tune my Sharp TV G0833PE to Foxtel
what is foxtel? is it a cable company? or satelite company?
SOURCE: how do you connect a sound bar 2000 series to a samsung series 45 tv?
what do i need to connect philips sound bar to samsumg 3d tv and 3d blu ray player, do i need all 3 cables in the book
