SOURCE: Flickering tv screen when playing playstation games.
I don't think it's a configuration problem at all. I do think that the set is not adjusting to the correct format. Most Stores have 30 day return policy. If it's over 30 days then they may not take it back. If you bought it online, then, the return may be difficult. If the return is not possible, then, contact Toshiba online and find a local Toshiba authorized servicer in your area. Hope this helps.
SOURCE: My screen flickers
Do you have video card installed in your motherboard?
If you have any do your have drivers installed for your video card?
If you do so pls check your settings for video and check foe the system requirements of World of Warcraft. Adjust your video setting to the specified recomendations found in the requirments for the game. System requirements located at the lower back part of your purchased cd.
SOURCE: P S 3 will
If you are having issues with the screen freezing after the press start
screen, this has to do with your automatic I.P. address configuration
on your PS3. On your computer go to the command prompt (to get to command prompt, click START > Run. In the box that opens up, type cmd. This will give you a black window with something written on the top ), Here is a pic:
Type in
ipconfig .It will show you the default gateway for your router/DSL. Type
that into your web browser to access your router configuration. From
there you can find the I.P. for the PS3 and default DNS servers. On
your PS3, go to the network settings and manually enter in the I.P
address for your PS3, the default gateway, and the default DNS
servers. After that, it should load up fine for you.
Note:
You will need the password for your router. Some have defaulted
"admin" as the password, or whatever you used when you set up your
router for your network.
If that doesn't work, HERE is another solution.
Hope that works!
Cheers!
IrishDruid
SOURCE: PS3 Flickers on and off on the screen
Is could be your TV and not the PS3. When the resolution of the screen changes, you TV will flicker to adjust to the new resolution. My TV flickers in a similar way when playing games of lower resolution than my HDTV.
SOURCE: Gateway sx2800-03 compatibility problems with Samsung 2494hm
you have the wrong video driver - go to gateway and redownload the video driver and install it reboot and presto...
