My printer is making a loud scretching noise and gives a 5100 error code
Canon printer is one of the best brands in the world many big organisation are relying on the canon printer, its unmatched printing quality and versatility makes it more best printing devices in the world, but every machinery devices causes problem, but don't worry we have a proper solution, Kindly visit us to get the proper solution
How We Support:
100% Fully Assistance
We Are Available 24*7
We Work Fast as per Customer demand
For More Info Do Visit Us: canon printers error code 5100
Toll-Free No: +1-888-633-7151
Try this simple fix of error code 5100
SOURCE: LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
SOURCE: Cannon pixma ip 4600 error code 5700 - paper jam
The error code 5700 is the sensor error.Replace the sheet
feed unit and then adjust the timing of the paper feed gears.
SOURCE: error code
Hi You can Try gave it go
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
SOURCE: cannon pixma mp145 printer error code e7 & e2
E2: Reload the paper correctly and press [Black] or [Color].
E7: The cartridges are not installed in place.
These are from the manual.
SOURCE: printer makes loud noises while powering on, and
The 5C00 code is for purge cam sensor error meaning an error occurred in the purge unit. You can remove the purge assembly and clean out all the ink covering the moving parts. You can clean it with isopropyl alcohol or just water. If no luck, replace the purge unit, will be around $30. This is the part number, if you need to replace it: Purge unit (QM2-2925).
