Please help me! i have a mixer yamaha AW2400, i want reset but i dont know howto reset it!
I just got a yamaha mixer going by plugging a drum machine then a phone into the rca tape in. Then I plugged a guitar into the different channels. Most of the channels started working again.
I do not know what you mean by 'resetting'.
Here's the manual:
https://usa.yamaha.com/files/download/other_assets/9/335089/aw2400_en_om_b0.pdf
Here's the manual:
https://usa.yamaha.com/files/download/ot...
SOURCE: Howto reset the Motorola HDT101 DTV Receiver?
DTV says to call them and they would be happy to tell ya as Im not a dtv subscriber and they dont wanna know me Sorry but do report back please and let us know!!
SOURCE: replace amilo Li1718 laptop cmos battery howto
the battery will see on the back or side of your laptop, press the two together and lock up slowly, ,,,,good luck
SOURCE: transmission line leak howto change lines
You can easily change these by disconnecting one end from the radiator attach point and the other from the transmission attach point, install the new line, check your transmission fluid level (because you will lose a little when you remove the old line) and your done. Fairly simple procedure. Good luck.
SOURCE: howto reset cmos on toshiba 3500
You can just use a paper clip (straighten to a U shape) and short out the battery contacts.
If you are not sure, just leave the battery out for 20+ mins then put the battery back in the holder.
The BIOS settings will then be set back to th default settings, then go into the BIOS setting and set the Date and Time etc.
