Machine does not move forward or backward
SOURCE: the needle will only move backwards, not forwards
Have you looked for a switch, button or dial that may need to be moved to a different position?
SOURCE: the cloth does not move forward nor backwards, i
If it's computerized make sure you have everything set back to auto. If you hit any adj you might have inadvertly turned them off. If it is not computerized remove the plate and remove the bobbin and investigate those areas to make sure you don't have something stuck.
SOURCE: The machine won't go forward
It sounds to me like the feed dogs are in the down position, what do you have the machine set to stitch at?
SOURCE: Machine won't sew forward, moves
hi there
please check rotation direction if u are use clutch motor.turn off the machine and then descharge motor and pull the plug and put it in other direction if u are use singel phas. if u are use machine with conrol box please tell me the model and i will answer u.
ashraf abozid
[email protected]
SOURCE: The Feeder Dogs are not moving forward or backwards on my sewing machine.
Are the Feed Dogs dropped? Check your manual for the location of the switch. .... otherwise your mechanism has been compromised. Take it in for repair.
