Hi Harry,
Your Module number is 2271.
1. To set the time, press and hold button A (left top) until Seconds digits start to flash.
2. Press button D (lower left) to move flashing in the following sequence to change other setting:
Seconds >> Hour >> Minutes >> 12/24 Hour Format >> Year >> Month >> Day >> (Then back to Seconds)
3. While a setting is flashing, use E (+) (bottom right) and B (-) (top right) to change it.
Note: When in the 12/24 Hour Mode, use E and B to toggle between 12-Hour and 24-Hour Mode.
4. Press buton A to exit setting screen.
Your time should now be set.
You may also download a manual for watch/Module number:
http://pathfinder.casio.com/resource/manuals/module_2271.pdf
This should give you all the info you need to operate all the functions of your watch. Thanks.
Regards, Bill
