Purchased at Menards ModelEHCTMER010 Menards SKU:3681816
SOURCE: resetting outdoor light timer
I would unplug the timer. Change the setting to 6 hours then plug back in.
SOURCE: Setting the timer
Click on the link below
to download your manual if you see your model listed.
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
You can install a
photocell for six to ten
dollars which you can wire in series with your timer output. The photocell that
will bypass the daylight time cycle from 8am-12pm.
SOURCE: Utilitech Outdoor Digital Photocell
SearchElf - Find Utilitech Timer Instructions
Here is a link to the instructions.
SOURCE: Timer has worked in the past as programed.
I test timers.
Timers go bad.
EJ351 has 1 year limited warranty.
Wiring is correct or timer would not operate.
Bulb is good.
I would reset timer again and re-program.
If timer still will not function, then timer has gone bad.
Following page has manual:
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers/ej351c.aspx
Reset instructions: Move the control lever to the OFF-CLEAR position for about
20 seconds. The red indicator light will go off and any previous
time settings will be cleared from memory.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
SOURCE: need instructions to set a intertek timer BND-60/U4N
There are many BND-60 timers
1) Do you mean Intermatic timer? Instead of intertek?
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
2) Is this BND-60-u or BND60-b analog timer from china?
http://waterheatertimer.org/How-to-set-timers.html
3) is this BND-60 programmable timer from china?
http://waterheatertimer.org/Woods-timers-and-manuals.html#46-1022
4) Add comment and include photo of timer, or describe timer in detail for possible identification and further assistance.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
