SOURCE: 1 handle pull and turn bath room faucet no hot
a common fault if the handle is forced the spindles get worn best to replace
SOURCE: I have a Price Pfister Model no. 808 DK00 single
It's likely that you have some sediment that has accumulated in the cold water valve and has clogged it. The model number you have cited above is only for the trim (rather than for the valves behind it). Assuming that you have a Price Pfister valve, they don't have built in filters, so you're probably going to have to either clean or replace the valve.
SOURCE: we have the price pfister bath clean out drain
you can remove the overflow plat,(check to see if you have 1 or 2 screws in the plate,the new one must match.The strainer piece in the bottom of the tub,is difficult to remove,but it can be done with a little effort and wd-40,the straineris a standard 1.5 inch npt (national pipe thread)
SOURCE: My price pfister single handle shower/bath control
There may be 2 pins if under ring the collar has multiple holes.remove pins & unscrew ring... or it could be just stuck from age..
SOURCE: I have a price pfister pull out kitchen sink 533
There is a restriction in the valve or the stop from supply is restricted,check stop at sink to make sure it is opened all the way,if it is then turn off water supply disconnect hot water to faucet take container open valve slowly to see if it is restricted,if that is open and water flow is good.Then it is in the faucet you must then disassemble hot side cartridge and see if there is some type of blockage if none visible the with hot side disassembled slowly open valve to see if you can flush out any foreign matter (note the way it is disassembled so you can reinstall exactly how if was taken out to avoid any reassembly problems).
