raphael mutinda musyoki Posted on Nov 24, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon ir advance c5240i error code e0000020-0491
Terry
Level 3:
  • Canon Master 11,377 Answers
  • Posted on Feb 20, 2020
Terry
Canon Master
Level 3:
Answers
11377
Questions
Helped
4619917
Points
152765
5 Related Answers
Anonymous
  • Posted on Aug 05, 2008
SOURCE: Canon IR 8500 Error code E000069-0000
You have a high-voltage leak to the transfer corona. This could be due to several different things, usually it's a dirty corona, maybe excessive dust or toner in the corona assembly. Toner conducts electricity and can leak voltage from the transfer corona to the frame. It may also be the "end-blocks," the thing in the back of the machine into which the transfer corona plugs when you close the drawer and lift up on the green handle. These crack and can cause intermittant failure.
I would start by taking a can of air and thoroughly blowing out the corona assembly and see what that does for you...
Sunil Rathod
  • 199 Answers
  • Posted on Feb 26, 2009
SOURCE: canon ir 2200 Error code E000064-0000
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
YES: Clean the contact, and set it once again.
2. Wiring
Is the wiring between the contacts for the following normal: DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
a. DC controller PCB (J301) <-> composite power supply PCB (J136)
b. composite power supply PCB (J130-7) <-> primary charging roller contact
c. composite power supply PCB (J130-1) <-> developing assembly contact
d. composite power supply PCB (FT133) <-> transfer roller contact
NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
Try replacing the composite power supply PCB. Is the problem corrected?
YES: Yes.
NO: Replace the DC controller PCB.
Anonymous
  • Posted on Nov 20, 2009
SOURCE: Canon IR C3200 Error Code E000020-03C0?
plz tell me reason of e602 code in canon ir c3200
Anonymous
  • Posted on Feb 08, 2010
SOURCE: Canon IR3300 showing the error code E000602-0003
ERROR CODE E000602-0003 what i do
Anonymous
  • 1219 Answers
  • Posted on May 04, 2010
SOURCE: canon ir 3530
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Codice di errore E000196-000f
English only on Fixya please. We are a North American website!
Canon iR Advance C3325i - Error Code
Printcopy.info https://printcopy.info > ...
Code: E196 000F ; Description: Communication error. The number of read/write job data to the DCON EEPROM exceeded 100. ; Remedy: [Remedy] Turn OFF and then ON the ...
E196-000F-05 Communication Error; ...
ManualsLib https://www.manualslib.com > ... > Service manual
Canon imageRUNNER ADVANCE C3500 III Series Manual Online: e196-000f-05 communication error, E196-0100-05 Communication Error, E196-0101-05 Communication ...
Canon error code E000196-1BFF
Copytechnet https://www.copytechnet.com > ... > Canon
Feb 21, 2019 - Hi guys, Can anybody tell me what this error code means on a Canon IRAC 2225? E000196-1BFF? Thanking all of you in advance Doug.
IRA C3525 E00196-00f
Aug 11, 2023
i-sensys MF8450 error code E000196
Sep 15, 2019
More results from www.copytechnet.com
Canon imageRUNNER ADVANCE C250i. I have error code E00074:000
Question edited for clarity.
Question moved from Washing Machines category!
It's not good news
Canon IRC 2030 E000074-0000
Feb 8, 2012 - E074 is an Error in the Primary Transfer Disengagement Control. Check SW1 ( Primary Transfer Disengagement Switch) for Displacement. **Knowledge ...
CQ Error E000074 Canon c2030i - Copytechnet
Aug 29, 2019
Error Code IR Adv C2030i - E021-0120 and E074-0000
Dec 5, 2018
iR C2020 error E074-0000 - Copytechnet
Jun 17, 2020
canon image class advance c2025h e000074-0000 error
Sep 25, 2017
Canon iR Advance C250i - Error Code
Printcopy.info https://printcopy.info > code=E074-0000
Code: E074-0000 · Description: Primary Transfer Roller disengagement control error. Signal was not detected although the ITB Pressure Release Switch was turned ...
Canon iR Advance 4045 error code code:E110-0002
There are several possibilities for the cause of the error message. Discerning which is applicable may well be a job for a technician. The error code E110-0002 on your Canon iR Advance 4045 indicates a failure of the Polygon Motor (M11). If the connector is not loose, replacement of a component may be necessary. It would likely require a Canon service representative to determine which, although the error message suggests the Polygon Motor.
  1. Check connection of the Connector (J1/J7/J10/J21/J208/ J8142/J8143).
  2. Replace the Laser Scanner Unit.
  3. Replace the Polygon Motor (M11).
Code d'erreur Canon Support for imageRUNNER ADVANCE C5250; erreur de projet bootable DL
Question edited for clarity and your French Typos.
Question translated to English.
This is a North American website and we only speak English.
All the answers are below and all in English
https://www.google.com/search?q=imageRUNNER+ADVANCE+C5250%3B+bootable+DL+project+error
Canon USA https://www.usa.canon.com > Canon Support
Find support for your Canon imageRUNNER ADVANCE C5250. Browse the recommended drivers, downloads, and manuals to make sure your product ...
imageRUNNER ADVANCE C5250 - Support
Canon Central and North Africa https://en.canon-cna.com > support > products > imag...
Canon · Consumer Product Support · imageRUNNER Series Support - Download drivers, software, manuals. Product range. Canon imageRUNNER ADVANCE C5250. iR-ADV ...
Canon ir-adv c5240i when there is no jammed paper it shows me paper jam how do i fix it fixya - did not match any video results.
Make sure you have opened the drawers and opened and closed all the doors. Look for little levers and light sensors throughout the machine to see if any of them are blocked by a torn scrap of paper.
old marine
old marine
ZJ Limited
ZJ Limited
