Go in to Settings Menu and then to Lan IP's and change it.
Testimonial: "There is no option in the modem menu to change the LAN IP's. Maybe the UI Firmware has been restricted for simple set-ups for plug-n-play operations. I will attempt to include the screenshots of the available menu options - which are extremely limited. https://screenshots.firefox.com/5H0YWfSHywg9dkAq/192.168.8.1 Thanks for your interest."
SOURCE: how do i change my lan IP so my router works
Hi!
Start by opening up a web browser (it doesn't matter if it can get to the internet or not, as long as its from a PC connected to the router) and, assuming the LAN address is still the default, goto the address "http://192.168.2.1" click on "login" and you will be prompted for a password.
Again, assuming everything is still default the password is not set and you can just click "Submit."
On the left side you will see a menu, underneath LAN click on the "LAN Settings" link. You will be presented with a page were you can set a new IP address for the router. Once you change the IP and click "Apply Changes" the IP of the router will be changed. Once the device finishes restarting you will now have to use the new IP address you just entered, in you browsers address bar instead of 192.168.2.1, in order to see and configure the settings of your router.
Hope this helps! Here is a link to the manual for product incase you get stuck. The juicy stuff you want is on page 33.
