Https://www.philgeps.gov.ph/GEPS/log-in.aspx
click above link go to right hand corner top
SOURCE: Username and password
You will probably need to reset your router to get access to it again with a known username and password. BEWARE THIS WILL PROBABLY RESET ALL CONFIGURATION INFORMATION AND YOU WILL BE REQUIRED TO COMPLETELY RECONFIGURE YOUR ROUTER INCLUDING POSSIBLY ISP SPECIFIC INFORMATION. If you cannot do this including knowledge of all the required answers and proceed anyway you may lose access to your internet connection until this is successfully done. Proceed beyond this point AT YOUR OWN RISK.
Follow the link below to determine the model of your router
Router Link
As your profile indicates you are from Australia -- there is a link at the top of the page for a DI-624+ that may also apply to you.
If this does not work or your model is not a DI-624 as indicated try the following Assuming you have a DLINK router
Go to www.dlink.com
Choose your country
Choose Support
attempt to access product information -- if your model does not appear there may be legacy products link on the page to choose
Download your user guide.
The following link may provide an emulator for your router to allow you to preview the configuration process (this does not configure your router. You may have noticed this emulators link earlier when accessing product information above, if you could not use the link.
Emulators Link
AGAIN PROCEEDING BEYOND HERE CAN RESULT IN THE LOSS OF ACCESS TO YOUR INTERNET SERVICE -- proceed with care.
Doing this will may require you to configure specific ISP required
entries into your router to restore internet access, I do not know what
those requirements are now. I may be able to research them if you
provide information about your internet service provider such as their
web site or help/support web site. Be aware that you will require all answers for this before doing it as you may not have internet access again after starting this until you successfully complete this. With all the previous warnings in mind you can consider the following step.
Using the instructions in the user guide you can probably reset your router and get access to the configuration.
SOURCE: I forgot the router's username and password.
Try admin, admin. If that doesn't work press the reset button and it will restore the factory settings. You will have to reconfigure the router.
SOURCE: I forgot the username of dlink wbr-1310 wireless router
As an initial info try to do a hard reset on the unit, this process will restore the system into a original settings. you can find the reset switch on either on the left of right sight of your router.
or
you may visit this SITE to recover again your current password without erasing or removing the current settings made.
Reset Password.
Hope this idea helps you.
Thank you for using fixya.
SOURCE: Forgot username/password for Dell Wireless 2350 Broadband Router.
Do you mean you have forgotten the wireless password for your network?
If so , there is are several tools available online which recover the wireless key as long as you have previously connected to that network from your computer.
Try http://www.nirsoft.net/utils/wireless_key.html
