Electronics - Others Logo
TRAD TECH Posted on Nov 13, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Greetings! My 170Kw generator does not start. It shows a warning sine and something like a digital wave. What could be the problem?
Larry
Level 3:
  • Master 5,042 Answers
  • Posted on Nov 14, 2017
Larry
Master
Level 3:
Answers
5042
Questions
Helped
1239536
Points
18413
Do you have the manual for it?
5 Related Answers
Curtis Richner
  • 461 Answers
  • Posted on Dec 19, 2008
SOURCE: Monitor 2400 heater will shut down when I run My generator
A UPS unit might work. Electronics need steady clean power.
Anonymous
  • 320 Answers
  • Posted on Jan 27, 2009
SOURCE: i want c code for
please click on the below link or copy the URL and paste it in the browser.. Appendix A will give you the code.
http://www.ee.ic.ac.uk/pcheung/teaching/ee3_Study_Project/lab3.pdf
Thank you....
Anonymous
  • 4 Answers
  • Posted on Feb 14, 2010
SOURCE: Is true sine wave better than modified sine wave.
To make a long story short, I've only had trouble with the Xantrex XS-400. There's only one review at Amazon and it's mine! Have a look.
http://www.amazon.com/XS400-400w-Sine-Wave-Inverter/dp/B000A7MW5E/ref=sr_1_1?ie=UTF8&s=sporting-goods&qid=1256963563&sr=8-1
Richard
nitrospawn
Ibe Chukwudi
  • 290 Answers
  • Posted on Feb 25, 2010
SOURCE: I would like to run my Canon i550 printer with a
pure sine wave will be the best option ,but note it is not very possible to get a pure sine wave type
galvinfranks
  • 3 Answers
  • Posted on Mar 19, 2011
SOURCE: hello is this ups a
The manual states when running on AC, it is the same sine wave ouptput that comes in. When running on DC, it is a modified sine wave.
Generator burning my electronics up
take you generator in and have the output tested for correct voltage and sine wave configuration
electronics rely on a perfect sine wave ac current as a manufactured sine wave affects electronic components such as capacitors, transistors and diodes
generator sets that run an alternator ( not an inverter ) have a pure sine wave and have less affect on electronics.
go google and type in search headings like ---sine wave, inverter sine wave, sine wave affects on electronics, alternator operation and inverter operations and then you may get a pointer as to why your inverter gen set is affecting your electronics
tip
WHAT IS A POWER INVERTER?
A power inverter is an electronic device that converts electricityfrom one form to another. Power inverters have become more popularrecently as the technology has become more efficient and much moreaffordable.
The most popular use for a power inverter isconverting battery electricity into mains electricity. For exampleconverting your car batteries' 12 volts DC into mains electricity 240Volt AC (Australia) or 110 Volt AC (USA).
WHAT POWER INVERTERS WILL HELP YOU DO
  1. Power inverters enablemains operated electrical equipment to be used even where there is nomains outlets, like in your car, caravan or even on your boat!
  2. Powerinverters bring creature comforts from home when you go camping orcaravaning allowing you to use your TV, fridge or electric shaver infact most of the normal mains powered conveniences from the home.
  3. You can charge your laptop in the car even if it doesn't happen tohave a 12 volt adapter. In fact a power inverter can be a very handygadget just to have in your car for those times you need to use a mainspowered appliance while you're away from a power socket.
WHAT TO LOOK FOR WHEN BUYING A POWER INVERTER
Apartfrom looking for a good quality well priced product there are a coupleof important elements to consider when selecting your power inverter:
HOW MUCH POWER IS ENOUGH ?
Powerinverters come in a range of power capacities so selecting the rightone for you is very important. Your power inverter needs to be able toprovide sufficient power for the equipment you want to use it with.
Here is a brief check list:
  1. Check the power consumption for the device you want to power
  2. Allow an additional 20% free board
  3. Add the power for all the devices you want to run at the same time
Note also that devices with induction electric motors like an power saw mayrequire 3 to 7 times the operating power when they start.
Usingan under-powered power inverter may damage it or the appliance you aretrying to use, so be sure to check the specific wattage requirementsand operating instructions for appliances / tools to be used.
PURE SINE WAVE INVERTERS
Normal mains power is known as Alternating Current (AC) and is a sine wave shape like the black line in the drawing below
Pure sine wave (black) versus modified sine wave (red)
Atypical power inverter produces a 'modified sine wave output' like thered line in the drawing above. While this works for most appliances,light dimmers, variable speed drills, sewing machine speed controls,some laser printers etc. will not operate correctly with a modifiedsine wave power inverter.
Pure sine wave power inverters areespecially designed to provide a more accurate sine wave output and socan be used with these appliances, but unfortunately they are moreexpensive.
Check with your with appliance manufacturer or itsspecifications to confirm if you can use a conventional power inverteror will need a pure sine wave inverter.
WARRANTY
One of thegreat things about electronic equipment is there is no moving parts(although there is a fan in some models) so you can expect a longserviceable life from a power inverter.
STANDARDS
Powerinverters generate dangerous mains voltages so ensure the product youchoose is approved for use with your mains voltage and supplier.
Powerinverters can also generate electro-magnetic radiation that caninterfere with other electronic equipment such as radios transmittersetc. Check for compliance with relevant standards such as C-Tick etc
SAFETY
Powerinverters can generate potentially lethal voltages so the utmost ofcare should be exercised using them to avoid accidental electrocution.
SUMMARY
To select your power inverter carefully check the power requirements for the appliance(s) you intend to use it with.
  1. Start power - Allow up to seven times for an induction motor
  2. Operating power - Allow a 20% margin
  3. Pure or modified sine wave
on Mar 04, 2010 • Electronics - Others
Low voltage output 170 volts
Check your voltage meter, so it measures correctly, probably generate your UPS is not pure sine wave, but a modified sine, then the simple measuring devices to display the wrong value.
Why is cyberpower 550va output voltage only 80 volts? Battery underload is 12+.
2answers
Powerhorse 4000 generator only has 110v output
to get that voltage , it would have to be revving very high
volts on a gen set are set by engine rpms
start it again ad keep manual control of the governor lever and adjust the speed screw ( controls the spring tension to the gov lever) to the 240 v output
a straight ac gen set is a pure sine wave --it is the inverter sets that have a squared of sine wave
2answers
Frequency Inverters DC-AC
I highly suggest you invest in a good quality inverter. For most equipment either pure or modified sine wave is fine. I would suggest you install a line conditioner after a UPS for any computer products. The line conditioner stabilizes the voltage much more closely than a UPS will.
As far as building your own, I've taken apart a lot of UPS models which have a DC-AC converter in them and they are filled with lots of heavy heat sinks, transistors, resistors, capacitors, etc. You can usually find these very cheap since the batteries die but the converter is fine. Check the input voltage of the original unit and start from there to make one easily that has everything already assembled with minor modifications.
1helpful
Black max 7kw generator high voltage output
Those voltage readings MAY be normal.
The AC waveform may cause your meter to read inaccurately. You would need to use a TRUE RMS meter to accurately read the voltage.
The siple meters actually read the AVERAGE voltage and then are calibrated to mulltiply it by the "form factor" for a sine wave. OFTEN these generators don't produce a clean sine wave. A square-ish wave will read higher on the garden variety meters.
Compare the brightness of a lamp comparing to when run on your utility.
The frequency depends on engine speed ... yours is running a bit fast...check it under at least half load and if off, adjust the govenor slightly.
Top Electronics - Others Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you an Electronics - Other Expert? Answer questions, earn points and help others
