Question about KitchenAid Microwave Ovens
Flickering light on kitchenaid microwave khhc2090sss
When Heating the surface light is flickering light on kitchenaid microwave khhc2090sss but it heats normal. What causes this and is it unsafe?
    Sergeant:
  • 228 Answers
If you're referring to the cavity light, it's possible the bulb is just loose in its socket. The cover has to be removed to access the bulb.
Posted on Nov 10, 2017
6ya staff
SOURCE:
Anonymous
SOURCE: GE Over range microwave, JVM1660
Was it the magnetron. Ours just gave up the ghost(heat) yesterday.
Posted on Nov 19, 2007
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Kitchenaid KHMS155LSS 1000 watt microwave makes grinding noise
Chances are you have a bad stirrer motor or the stirrer blade is jamming or loose on the motor shaft.
Your owner's manual should tell you how to remove the stirrer cover to check it.
If for some reason you don't have your owner's manual, you can download it free here, as well as the parts manual for your model.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jan 01, 2009
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: top of over-the-range microwave hot to touch; normal?
A little over 100F is hotter than most folks can stand to touch, so it may not be seriously hot.
But if you're concerned, you might see if your dealer will let you test another one or a similar model at the store to see if it also gets that hot.
Otherwise, you can return it to be safe or you can contact Panasonic consumer electronics support here or at 1-800-211-7262 to ask them about it.
Posted on Jan 03, 2009
Anonymous
SOURCE: AC925EQK microwave. flashing light, not heating up
Mag tube Shot
Posted on Aug 29, 2009
Testimonial: "thanks very much"
A Miller
  • 8404 Answers
SOURCE: no heat on magic chef microwave
Check the door safety interlock switches.
Posted on Dec 29, 2009
Our microwave does not consistently come on. When we put in the time to cook it tells us to open/close door. If the cavity light comes on then it works, if not it doesn't work. Please HELP! Thank you
Sounds like you have one or more faulty micro-switches for the door. They are not expensive to get, but your service center will likely charge you a lot to fix it. If you are handy, you can pull the case off and replace them yourself.
Oct 18, 2016 | KitchenAid "KHHC2090sss Microwave Hood...
Microwave won't heat for first minute - starts working normally after that.
The magnetron may be defective. You can replace the magnetron, there is no other possibility.
Jan 16, 2013 | KitchenAid KHMC1857WSS Microwave Oven
Hi there, unit worked fine this morning heating coffee, now has a different tone, and not heating. Timer works, interior light comes on, turn table rotating. Unit is a KEMC308KSS01
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Dec 21, 2010 | KitchenAid Microwave Convection Oven
Runs normally, but makes loud hum. not heating. in defrost mode, loud hum, then normal sounds, then loud hum, then normal...
heatman101
Aug 15, 2010 | KitchenAid KCMS1555RSS Stainless Steel...
Recently the light flickers and gets dimmer, then back to normal, several times while heating something in the oven Just wondered if this is some simple thing to take care of, or should we consider...
Sounds like an arcing switch or connection, or maybe the light itself is not making a good connection. Check the plug in the outlet socket to see if it gets hot after heating something. Wiggle the cord to see if the light flickers. The door switch is a microswitch type and should make a positive 'click' when operated.
Feb 05, 2010 | Microwave Ovens
My KCMS185JSS-5 microwave has no heat. It seems to be running, the light and turn table all work, but it won't heat water.
hi..Your micro hood is "shot".so it is not working properly.
The food may not be heating,but the electrical and the walls
of the unit might heat.This may cause sparking and melting
of the interior of the unit.
check it out..
thank u..
kindly rate my response..
Jun 15, 2009 | KitchenAid Microwave Ovens
Pre- heating of Microwave
Place a bowl or mug of water in the oven while preheating.
May 15, 2009 | Microwave Ovens
Microwave stopped heating, evenything else works
Jan 03, 2009 | KitchenAid KCMS1555RSS Stainless Steel...
Microwave Ovens Logo
455 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jerry Greenberg
Jerry Greenberg
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
