Is the child lock on? Try turning it off and on again...
Unplug for a few minutes then plug back in. That may cause it to unlock
Hi Janet.
see if this link helps you out.
My front loader Electrolux washing machine is on lock and can open it...
SOURCE: Electrolux XL8KG Front Loader Washing Maching
I've found that a similar thing on my Zanussi appears when the filter on the output is clogged. Removing muck and hair from the filter usually solves the problem
SOURCE: bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
SOURCE: unusual display on panel (padlock) machine can't be programmed door is not locked however
i just went through the same thing.......you need to hold the option and extra rinse buttons simultaneously for 6 seconds, this will unlock it.....so turn the machine on and press the two icons, dont worry about the beeping and flashing after 6 seconds the padlock symbol will go and you can use the machine as usual.....i wish they put that 'minor detail' in the manual...cheers!!
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
SOURCE: electrolux ewf 1090, have an electrolux ewf1090
ewf1090 washing machine not working?
error E50 is displayed?
but no reference in manual that helps.
Hello Elizabeth P Cochran - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
