The website is currently up, you may need to clear your temporary internet files in order for it to display the current version instead of any cached version you may have.
The Error 404 "Page not found" is the error page displayed whenever someone asks for a page that's simply not available on your site. The reason for this is that there may be a link on your site that was wrong or the page might have been recently removed from the site. As there is no web page to display, the web server sends a page that simply says "404 Page not found".The 404 error message is an HTTP (Hypertext Transfer Protocol) standard status code. This "Not Found" response code indicates that although the client could communicate to the server, the server could not find what was requested or it was configured not to fulfill the request. The 404 "Not Found" error is not the same as the "Server Not Found" error which you see whenever a connection to the destination server could not be established at all.
The 404 or Not Found error message is a HTTP standard response code indicating that the client was able to communicate with the server, but the server could not find what was requested.
The web site hosting server will typically generate "404 - Not Found" web page, when users attempts to follow a broken or dead link, hence the 404 error is one of the most recognizable errors users can find on the web.
A 404 error should not be confused with "server not found" or similar errors, in which a connection to the destination server could not be made at all. A 404 error indicates that the requested resource may be available again in the future; however, the fact does not guarantee the same content.
404 Not Found Error Emails
The 404 not found error notice is something webmasters hate. But the
fact is broken HTML and image links do occur. Here is how to get
real-time email notices when they do occur.
Yes, I know log files give details of errors. But how often do you
check your log files? Unless you examine them every day, it could be
weeks even months before you discover the 404 not found errors. By then
hundreds, even thousands of visitors may have left your site never to
return, nevermind the lost advertising revenue or sales, because they
ended up on a 404 not found error page. 196 404 Not Found Error Messages
Recently I encountered this problem when I made some changes to an
existing website. I set up a 404 not found error email notification
system, and immediately my mailbox was flooded with reports of broken
links, search engine bots trying to crawl old nonexistent files, broken
image links and missing favicon images.
I was shocked just how many error messages I received - 196 404 not
found error messages in 24 hours. It even caught an issue with one of my
affiliate campaigns. If I didn't catch that, my AdWords campaign would
have sent traffic to a non-existent URL. It could have ended up costing
me thousands of dollars in wasted advertising and lost sales. How to Set Up Your Own 404 Not Found Error Email System
If you want to take a proactive approach and get real-time notices of
404 not found error messages as they happen, then you should set up
your own real-time 404 not found error email notification system.
Here's how I did it: By the way, your server must have PHP enabled
otherwise this method doesn't work. Ask your server administrator
whether your server is PHP enabled and if it isn't, then ask them to
enable it.
Also remember to backup any files you intend to edit. If something goes wrong, you can always revert back to the previous file.
The system uses two files; the .htaccess file which tells the server
where to send users when there is an error, and the 404 not found error
file which sends the 404 not found error email notices to you.
someone asks for a page that’s simply not available on your site. The
request.
request.
I had the same problem and changed the battery on Monday. Works fine. There are just four small screws to remove.
Replacement battery can be found here: http://newmp3technology.com/404-battery.htm. I used them and can confirm that the battery comes with the right connector for the Archos 404.
