SOURCE: fridge is not cooling
You probably need an adaptive defrost control which is located in the back right hand corner of your fresh food compartment. You have to dismantle the overhead controls to get to it. If you had to defrost your coils, and the heaters test good, then you probably need the above control.
SOURCE: my fridge is warm, the frezzer is cold but not
Hi, Look inside the freezer and see if there is frost building up on the rear panel inside. If there is frost, Remove the rear panle and check the defrost heater and bi-metal switch (must be tested while cold) for continuity, If either of these switches show an open circuit, replace it.
If these parts test ok, replace the defrost timer.
Other things to look for, make sure fans and compressor are running.
Please let me know if this helps or if I can assist you further.
Vic
SOURCE: fridge and freezer not getting cold
If it was layed down to move and not let sit for a while before using it again it would not work. Somtimes leaving in off and let it settle will straighten it out but not all time. The oil in the compressor get into the cooling lines and blockes the freon. Other than that, check the condenser coil which are near the compressor. They should be warm when the compressor is runnin. If they are not warm there is a compressor or freon problem.
SOURCE: hi,i have fisher pakel E522B
HI,CHECK FOR CONTINUITY ON THE DEFROST ELEMENT AND B-METAL IF THOSE COMPONENTS PASS THE TEST MAYBE THE TIMER OR DEFROST CONTROL COULD BE BAD IN YOUR REFRIGERATOR..GOOD LUCK..
SOURCE: my frezzer works but refrig doesnt cool well
open the freezer door,do you hear the fan blowing,if not hold in the door switch for a few deconds and let it go,if the fan isn't blowing this is your problem.all that happens is the freezer gets cold,the evap fan blows cold air through the damper and into the fridge section so if the freezer is fine you have a bad evap fan motor or the damper isn't opening all the way
