Welding Tools Logo
d
david kendrick Posted on Oct 24, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My millermatic 211 autofed wont fed wire - Welding Tools
Kardoc
Level 3:
Top Expert:
  • Welding Tools Master 7,503 Answers
  • Posted on Mar 18, 2019
Kardoc
Level 3:
Top Expert:
Answers
7503
Questions
0
Helped
2756793
Points
58323
3 Related Answers
luis_david
David Soto
  • 414 Answers
  • Posted on Jan 12, 2011
SOURCE: My 211 Millermatic welder is
Your problem rely on the initial settings, your voltage is too high or your wire feed speed it's too slow. Compensate both, or just decrease you voltage.
luis_david
David Soto
  • 414 Answers
  • Posted on Aug 25, 2011
SOURCE: millermatic 211 temp light flashes when machine is
Hi:
By the description sounds like the trigger itself is the problem, have you try to bypass (bridge) the connection (disconnect the gun's plug from the machine and use a clip to bypass it at the machine's end) and see if the problem persists?
If the problem continues, then the problem would be the heat sensor.
Bill Boyd
  • 53816 Answers
  • Posted on May 05, 2015
SOURCE: New welder, only fed wire a couple times now it wont work
wire cannot be rusty as this rust comes off and jams the wire in the tip as well
Testimonial: "Its not jammed, the rollers dont roll to even push the wire when you pull the trigger"
Millermatic 211 when its plugged into 110 it welds fine but when i plug it into 220 the fan kicks on like normal but i get nothing on the gun and no wire feed shop said board miller says its a relay.
This machine is an auto adjust for different voltages.
The front end of the circuity is a PMPS or pulse mode power supply. No matter the input, the output is the same.
Most all small appliances today are built around this technology. I bet a small IC on the circuit board has gone bad. A good electronics repair man could fix this or you can get the board from Miller.
I have power to the gas solenoid on my millermatic 211. however no gas to the tip. tank 3/4 full. have gas to flare fitting that attaches to unit. do you think bad solenoid?
Guessing you measured the power at the solenoid and therefore you have a voltmeter.
Disconnected the solenoid wiring and measure the Ohms across the coil of the solenoid.
You should read some relatively low resistance 200, 500, 5000.
Not meg-ohms.
What make & model mig gun is fitted to this machine
Mig Guns & Mig Gun Spares - The Welders Warehouse
www.thewelderswarehouse.com/Welding/Mig-Welder-Gun.html
We have Mig Guns and spares to suit a wide range of Mig Welders. ... Torches are usually Euro Fitting and are typically fitted to professional mig welding machines of ... attitudes from people one is giving money to ! its great to get good service.
[PDF]POWER MIG ®(140, 180 MODELS) - Lincoln Electric
www.lincolnelectric.com/assets/...public/.../im890.pdf
Lincoln Electricshipment must be made by the purchaser against the transportation company at the time the shipment is received. SAFETY DEPENDS ON YOU. Lincoln arc welding and cutting equipment is designed and built with ... properly fitted and with proper grade of filter plate .... Semiautomatic DC Constant Voltage (Wire) Welder.
Millermatic® 211 MIG Welder - MillerWelds
2answers
the noise you hear is the relay for the wire feed,it means that your tension on the wire needs to be set,tighten it if it is too loose and loosen it if the roller on the feed is moving but the wire is not,also,make sure the wire moves easily in the handle,always keep your cords straight so they dont bind.
Burning up tips fast with Miller S-22A
tooslow and probaly too close to work piece try turning heat down a little also make shure you have a good ground/ maybe angle your gun a little more
Millermatic 211 temp light flashes when machine is turned on. fan is running and air flow is not blocked. if i unplug the little plug for the gun and plug it back in the wire will start feeding all by...
Hi:
Our MillerMatic 175 wire feed cannot be adjusted down enough. The rheostat seems to function, but even the lowest setting is now way too fast.
Your Millermatic 175 has syncronize wire speed-voltage feature in order to reduce the wire speed first reduce your heat (voltage). Try again.
If this was useful to you please vote. thanks.
My 211 Millermatic welder is experiencing burnback no matter how low I set the power. Why is it and what can I do to stop it?
What mig welder would you I buy to restore a old car.
I always tell my customers that the best machine for a body shop is a millermatic 212 if you have 220V available if not, go to a Millermatic 211 this is one is a dual voltage unit 110V/220V. if you can afford it buy a spool gun SG100 for all aluminum parts, the machine will cost you 999.00 and the spool gun 215.00. Best investment ever for your shop.
Top Welding Tools Experts
ADMIN Andrew
ADMIN Andrew
littlewheel
Are you a Welding Tool Expert? Answer questions, earn points and help others
