Microwave Ovens Logo
j
jim falato Posted on Oct 24, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I change the light bulb in a magic chef microwave?
NOEL
Level 3:
Top Expert:
  • Magic Chef Master 8,606 Answers
  • Posted on Oct 24, 2017
NOEL
Magic Chef Master
Level 3:
Top Expert:
Answers
8606
Questions
18
Helped
2321944
Points
68630
  1. Unplug the Magic Chef microwave from the wall outlet.
  2. Remove the screw from the light cover located on the left side of the underside of the microwave. ...
  3. Unscrew the light bulb, then screw in the new light bulb.
  4. Raise the light cover, then secure the cover with the screw that was originally removed.
More items...
How to Replace a Magic Chef Microwave Light Bulb ' Hunker
https://www.hunker.com/13407988/how-to-replace-a-magic-chef-microwave-light-bulb How do change the light bulb in magic chef microwave Google Search
5 Related Answers
Sanjay Pal
  • 37 Answers
  • Posted on Aug 03, 2007
SOURCE: Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Anonymous
  • 473 Answers
  • Posted on Oct 05, 2007
SOURCE: Magic Chef 1.0 cu. ft. Convection Microwave Oven
There are several things that could cause a microwave not to heat. Most common is the magnatron and some models have up to a 5 yr warranty on that part. Check the owners manual for that info.
Anonymous
  • 958 Answers
  • Posted on Feb 11, 2008
SOURCE: microwave
im not sure what a magic chef bulb is but you can check by opening the casing, the bulb is normally mounted on a fiber board and screwed on the metal part of the microwave,remove the two wires attached to it first, after unscrewing the screw, you can pull out the bulb holder and you can see if it is a replaceable bulb if it has a socket. you can use the old bulb holder , just replace the bulb. in some design, the bulb is mounted directly to the bulb holder, you have to buy the bulb mounted directly to a new bulb holder and use them all as an assembly. be sure to screw them back tight. tnx. i hope i was able to help.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Oct 20, 2008
SOURCE: Changing light bulb in microwave oven
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Anonymous
  • Posted on Mar 02, 2009
SOURCE: Microwave waveguide spatter shield burned through
THE PART IS CALLED A WAVEGUIDE COVER AVAILBALE FROM REPAIRCLINIC.COM
How do you install light bulb on mcw1611 magic chef??
I'm not finding a Magic Chef model MCW1611, but I do see they have models like MCM1611B and MCM1611ST. Maybe it's one of those?
Either way, I would suggest checking your owner's manual to see if it mentions bulb changes. If for some reason you don't have yours, you should be able to download it or a similar one here. https://mcappliance.com/manuals
If the manual doesn't cover bulb changes, then you would need to remove the outer cover to get to the bulb, usually located on the right side near the magnetron.
Feel free to contact me for further info.
William E. Miller
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
How to change a light bulb in microwave
Things You'll Need
30-watt incandescent light bulb
Screwdriver
Light
Remove the screw from the light cover located on the left side of the underside of the microwave. The light cover is connected to a hinge and will lower, but cannot be removed from the microwave.
Unscrew the light bulb, then screw in the new light bulb. hope this helps
Replace light bulb.
http://www.ehow.com/how_7614605_replace-chef-microwave-light-bulb.html
Here is one link that i've found. It didn't mentioned the exact model but i hope this one helps...
How do i change ligh bulb magic chef mcd11e3b
Unfortunately I do not believe that the light bulb is able to be replaced. I would go here http://mcappliance.com/emailus.asp?Inquiry=parts and send them a question regarding it.
Best,
Bob
Where can I get a light bulb and base for Magic Chef microwave model #MCP13E1ST?
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Just take the old one with you.
Replace light bulb in Magic Chef MCD1611
Remove cover and look for light. Special torx is required to loosen screws.
8helpful
2answers
5helpful
4answers
Top Magic Chef Microwave Ovens Experts
Jerry Naidoo
NOEL
NOEL
vince
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
