Yes there is its usually under hood clipped to brace for steering wheel. Mostly on right side if sitting on tractor.
SOURCE: my john deere lt155 has a punctured tyre, how do i
in the center of the rim remove plastic cap remove c clip retainer then pull rim and tire off the machine
SOURCE: John Deere LT155 Lawn Tractor has trouble going uphill
u can change belt yourself need belt size and have to remove cutting deck but check belt tension first if loose with brake off belt stretched out and slipping needs replacement
SOURCE: need instructions for changing a drive belt on a John Deere LT155
I have googled LT155 and came upon john deere LT155 lawn tractor(noncurrent). It took me to John Deere's site. I put in your model number and it had several catagories. I would try the alphabetical list, go to B and look for traction belt.
Good day.
SOURCE: The left blade on my John Deere LT155 stopped working
Besides the drive belt, there is a timing belt inside the mowing deck. The left blade is run by the timing belt. I imagine the timing belt is broken.
