Handle fell off suitcase.
Look and see if this link helps you out.. Where do get luggage handle fixed Google Search
SOURCE: Need parts to repair pan handle
I just had this problem! I took it to Ace hardware and the guys helped me out, big time. I have a PH-358 panhandle and the same piece fell of during a shoot into some brush and dirt outside.
We (they) fixed it using a #6 metric bolt and butterfly wing nut along with two grommets (3/8 ID and 5/8 OD). It worked perfectly! Not only does it hold the handle together but you can tighten or loosen the handle as well using the butterfly wing nut.
SOURCE: Bathroom Faucet Handle Fell Off
There is a small allen screw in the base of the handle- the part the stem screws into to turn the water to the on position. If you have lost the one for your handle call moen at 1-800-289-6636 in the US. Their hours are Mon-Fri 8-8 EST and Sat 8-18:30 or follow this link MOEN. In Canada 1-800-465-6130 and hours are Mon-Fri 7:30-17:00 EST.
SOURCE: Kenmore toaster oven handle fell off
Black and Decker Toaster Oven handle is loose and no way to get to the screws to tighten
SOURCE: I have a single-handle Moen
Yes you should have a lifetime warrenty. Call 1-800-buy moen for replacement parts. They generally are very good about taking care of their productc however be prepared for a extended wait to get through. You can buy after market or genuine moen part at most lowes or ace hardware stores. Hope this helps. Thank you
