Question about Amana Refrigerators
Where does Amana bottom freezer drain discharge to? I have manually defrosted the freezer. Water dropped into drain. Now water leaking out of the bottom at side of unit.
  • 29 Answers
The defrost water drains into a holding pan and is evaporated away. The video displays the most likely problem.
https://youtu.be/_MyOFwRWRTY
Posted on Oct 22, 2017
6ya staff
SOURCE:
Anonymous
  • 237 Answers
SOURCE: My Jennair Side by side has ice in freezer bottom and leaks water
This sounds like the defrost drain line is clogged and frozen. Every 8-12 hours the defrost cycle melts the ice buildup on the coils and is supposed to drain out to the pan under the fridge. Once this is blocked or freezes up the next cycles continue to put liquid water over the existing ice which then freezes, etc. till finall the area is frozen enough for water to find it's way out the door seals. You will need to take the back interior panel off the freezer side to view the coils and drain line. It will take lots of hot water to melt the ice in the drain area and the drain line in order to run a cleaning tube (basically a piece of 1/4" tubing like the water line tubing a couple feet long that you can force down the drain to make sure it's not plugged). Once you push the cleaning tube down the drain and can see it come out the other end in the drip tray pull it back out and pour hot water down it once more to watch that it drains fast. That should do it!
Posted on Feb 08, 2007
Tony Coultrip
  • 183 Answers
SOURCE: Kenmore / GE side by side defrost drain keeps freezing up
Check under the base, the tube must be clear to the water tray, often there is a rubber flow restrictor, this either perishes or blockes, either way remove it, defrost over night and then turn back on, should then work ok within 24hrs. Regards Adbvisor
Posted on Aug 23, 2007
David Coomer
  • 1073 Answers
SOURCE: Maytag side by side refridgerator
the drain tube is clogged or maybe frozen, remove the restriction and you will have no more problem
Posted on Apr 10, 2008
MNTECH
Carl Schulzetenberg
  • 1543 Answers
SOURCE: Water leaking from bottom left freezer/dispenser side
Take the metal back panel off the inside of the freezer, exposing the cooling coils. Below the coils, at the very bottom of the freezer compartment you will find a small drain hole. (Presently covered over with ice) Use hot (not boiling) water and a turkey baster to melt the ice and force hot water into the drain hole until the water runs out the drain hole (and into the defrost drain pan under the refrigerator) on it's own. This should be a Fix-Ya for your refrigerator.
Posted on Dec 25, 2008
Anonymous
SOURCE: Jenn-Air freezer leak
Apparently it is the drain behind the freezer panel on the inside and it is blocked. It needs to be unblocked and cleaned. You remove the food and the rear panel on the inside of the freezer. With a hair dryer (carefully) remove all ice build up and then unblock the drain line going to the pan under the refrigerator. The drain line can be cleaned with bi-carb and hot water (not boiling).
Posted on Dec 31, 2008
Refrigerator leaking bad at bottom after manual defrost still leaking
Ah the bottom. The drain pan is overfull and can not Handel the amount of water going into it. Normal running operation will evaporate any water left in the pan. You can pull out the fridge and drain the pan or clean up the water until it stops. Good luck
Sep 09, 2012 | Amana 22.6 cu. ft. Side-By-Side...
Buildup of ice on bottom of freezer compartment. Ice then melts and leaks out the bottom
sounds like you have a stopped up drain line where water drains out when freezer is in defrost mode. My Amana freezer does it quiet often.
Jul 15, 2012 | Amana ABB2224WES Refrigeration :...
Bottom freezer is all full of ice, what can I do?
The defrost drain is clogged. The defrost water is puddling up in the bottom of the freezer.
Thaw her out and remove the service panel. Unclog the drain. I use a hair dryer and a shop vac.
Amana bottom mount service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 22, 2011 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
Ice keeps forming on the bottom of the freezer - like a leak on the back side flows into the bottom toward the door.
When a refrigerator leaks water like yours, it is common for the problem to be nothing more than a clogged defrost drain. When the unit defrosts itself, the frost melt water drips into a pan underneath the evaporator in the freezer, and goes through a tube from there to the bottom outside of the unit. Since the water cant go down this drain, it backs up on the freezer floor, then eventually the kitchen floor.
Oct 06, 2010 | Amana 15.0 cu. ft. / 425 liter Upright...
Water collecting under produce bin which has to be collected every couple of days.Amana model # TX21VE 7.74 amps
Your drain is clogged. Every time it defrosts the water from the defrost should drain out to a catch basin under the ice box. That drain is clogged. You need to access the drain and clear it.
AMANA BOTTOM MOUNT SERVICE MANUAL
2 megs printable version
Helpful?
Sep 30, 2010 | Amana Refrigerators
I have an Amana BRD18V1 or V2, bottom freezer. About every two weeks it leaks water on the floor on the right hand side and i have to defrost the bottom part to get about an inch of ice out. I trust...
I assume you mean water leaking on floor of bottom freezer? There should be a small hole in floor in back to drain defrosted water down to pan under unit. This line might be clogged with food or frozen water. Carefully pour some hot/boiling water down tube to clear. You should see it empty into pan under unit where fan evaporates it.
Jul 15, 2010 | Amana ABB1927DE Bottom Freezer...
Leaking water
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 10, 2010 | Amana ABB2224D Bottom Freezer Refrigerator
LEAKING FRIG SOMETIMES SMALL PUDDLE OF WATER IN FRONT OF REFRIG
drain hole is plugged, usually frozen with ice, consult owners manual on how to defrost drain hole. Hot water usually does the trick.
Jun 09, 2010 | Amana ABB1927DE Bottom Freezer...
Amana bottom freezer: water leaking & ice build-up
There should be some kind of drain at bottom of freezer compartment to collect and run off any condensate that collects during defrost cycle.. Clean out the drain and snake out the line that leads from it. Right now the liquid is collecting where it should not and it will leak out the gasket when you have enough of it.
Sep 09, 2017 | Amana ABB1927DE Bottom Freezer...
Freezer leaks water!
luvbug, Your refrigerator is "frost free" which means it is automatically defrosts after the compressor runs 8 to 12 hours. The defrost cycle lasts approximately 30 minutes. If it is in normal condition, defrosted water goes through the drain into the drip pan under the refrigerator and then evaporates. The problem you are having is one of the most common - the drain line is clogged up. To fix it you have to remove the freezer drawer, defrost and clean the drain. The drawer removal procedure described in the refrigerator manual book. If you do not have one you can find it there: http://www.amana.com/amana/jsp/manual.do You will see the drain hole on the freezer floor by the rear panel. To defrost it you can use your hair dryer. To make sure it is open, run a cup of very hot water through the drain. Reinstall the freezer drawer and enjoy it! Gendos....post it back
Dec 21, 2006 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
632 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
