Why not ask an actual real question, form one in English. Centrifuge 5415 D and Centrifuge 5415 R it is not a computer at all. so is off topic here. did you read the manual first? no. https://www.nist.gov/system/files/docume...
it says electronics error 17
and to repeat the run, time to call for service, seems to me.
If the solutions suggested here prove to be unsuccessful, please contact Brinkmann Service at 800-645-3050 in USA and 800-263-8715 in Canada.
it is not a computer, it is Laboratory equipment.Why not ask an actual real question, form one in English.
https://www.nist.gov/system/files/documents/ncnr/Eppendorf_5415R_Centrifuge_Manual.pdf
AnonymousJun 18, 2021
15 seconds googled and bingo. why can't you?15 seconds googled and bingo. why can't you?
it said RErun the run. did you ? make sure not out of balance and make sure all parts mech are clean and not jamming. up. get it serviced? ALL MACHINES NEED THAT. or re-seat all CARDS IF POSSIBLE. (AC CORD PULLED FROM WALL)it said RErun the run. did you ?
You can't post conmments that contain an email address.
I don't see the service manual posted on the net, simply an operator's manual. Whether you can get such from the company's technical support is unknown as they have a lot of service contracts offered. You might post on Labwrench to see if someone has such and would upload it. Here are Eppendorf contacts and a superflous operator's manual: https://www.eppendorf.com/US-en/service-support/repair-service/ https://www.eppendorf.com/US-en/service-support/
I fixed many of the Eppendorf 5702R with Error 16. It is caused by failure in the main frequency converter PCB. In every case, the failing component was different from the other. You will have to test it and replace few compartments. In simple, Error 16 means failure in communication between the control and frequency converter PCB's. Any failure in the main PCB that results in lower voltage will cause that error. I hope I have a simpler answer. i can help if you contact me.
The Eppendorf manual states that Error 3 means that there was an anomaly in the speed sensing system. The corrective action is to leave the power on with the centrifuge not spinning for several minutes and the error should clear itself.
If the error persists, then the speed sensor is probably damaged, and the unit will need to be serviced by a qualified technician.
Align the magnet on motor support. Put it a litle closer to the board.
The imbalance sensor sends a signal directly proportional to the intensity of the magnetic field strengh from magnet. Pop off the display board and locate pin 12 of 8AF C515C microcontroller, its an A/D input, reading the imbalance sensor voltage. If the voltage on it goes below 1,5 Volts, it latchs on imbalance or error 2. The correct setting point is with motor stopped, if you shake manually the motor you have errror 2. Otherwise not.
Eppendorf AG: Please see our product page for the Eppendorf Centrifuge 5417 R. It has the manual for the Centrifuge 5417 C online as well: http://goo.gl/VCVVh.
If you have any further questions, please contact our technical support: http://goo.gl/fmoEV
Kind regards, Eppendorf Social Media Team Hamburg, Germany ([email protected])
i have centrifuge from eppendorf model: 5402... it is old model so the user manual is not available on web..
it looks fine on start .. but when i start a run it gives error or "Balance rotor" ... i am checking it every electronics but everythings looks fine.. kindly guide me what i could do.. [email protected]
